View Poll Results: Want a LCD Gauge Cluster?
Voters: 39. You may not vote on this poll
Interested in LCD Gauges?
#45
#46
I would hope you mean the other way around. The OEM analog RPM gage is woefully inaccurate. Ask anyone with a VAFC, Summitt or any other rpm switch.
#47
They're going to be a mix between analog and digital. See the picture here.
I will also need to probe some cars pretty soon. The process should take about an hour. Hook some stuff up. Drive around. Record resurgent. Probees will get a discount
PM me if you're interested. I need both 5spd and autos.
#49
On my car when I tilt the steering all the way down, I wind up never seeing the indicator lights. Your diagram looks OK with the indicator LEDs a bit lower, but if you could make sure all the important lights are still visible no matter how the wheel is tilted, that would be nice.
#53
update
I little snippet of some progress.
Code:
// Created by BlackThornDemon // See desc.txt for more info #include <Adafruit_GFX.h> #include <Adafruit_PCD8544.h> #include <avr/pgmspace.h> // memory management #define cel_height 48 #define cel_width 84 Adafruit_PCD8544 lcd= Adafruit_PCD8544(3,4,5,7,6); // globals // dummy lights // use byte because its 8 bit (int, short, etc. are 2 bytes) // array is in THIS order: // abs, airbag, battery, brake, brights, cel, cruise, door open, // left turn, over drive, oil, right turn, seatbelt, washer fluid byte dummyPins[13] = {22,23,24,25,26,27,28,29,30,31,32,33,34,35}; // Gauges // MAX input is 3.3V // ^^^^^ --REMEMBER THIS IT MATTERS-- ^^^^^ byte pinFuel =0; byte pinSpeed =1; byte pinTach =2; byte pinTemp =3; // Mileage // this is some cool **** // we're actually saving the odometer and trip // to the built in flash memory so it gets saved // NOTE: this method may never actually get used // as the developers estimate the built in memory // can only be accessed about 100,000 times // in all actuality nobody probably ever starts a car // in its whole lifetime 100,000 times much less a car // that's 14-18 years old already however in the sake // of longevity I will explore other options of saving // data (such as a SD card) int trip =0; int odometer =0; /* processing of on/off lights (i.e. abs, brake, etc.) */ void dummyLight() { } /* this is the base of the dummy lights if the input is 0-0.49 the light is read as OFF if the input is 0.50-1 the light is read as ON */ void CheckSignalDigital(int signalPin, int max) { // read the pin here so we don't have to read it 4 times float pinValue = digitalRead(signalPin); if(pinValue >= 0.50 && pinValue <= 1) { } // this is important because if the light was previously on // we need to turn it off else if(pinValue >=0 && pinValue <= 0.49) {} else PinReadError(); } boolean CheckSignalAnalog() { } void PinReadError(string pin, string error) { // print the error on screen nicely } void setup() { odometer =; lcd.begin(); lcd.command(PCD8544_DISPLAYCONTROL | PCD8544_DISPLAYNORMAL); lcd.clearDisplay(); lcd.setContrast(60); lcd.setTextSize(2); lcd.setCursor(0,0); } void loop() { for(int i=0;i<13;i++) { CheckSignalDigital(dummyPins[i], 1); } lcd.display(); delay(100); }
#58
More progress. Right now I'm looking in to making a can bus/obd board to keep the cost down.
Woot! free samples
http://www.obdsol.com/stn1110/
Woot! free samples
#59
4th gen obd is very very very very slow
you should buy a obd reader and see how the rpm's correlate to the gauge when you rev before you go too far(im not sure if our obd port shows the speedo?)
220k+ A32
18
09-22-2015 11:39 AM
RWCreative
09-21-2015 11:01 AM
