4th gen Maxima 80K maintenance recommendations
I snagged a low mileage 1998 GLE that was well taken care of by 1 owner and attached to a remarkably clean Car Fax. Looking for recommendation as to what should be serviced and/or maintained at an 80,000 mile/15 year interval. I've already completed the following:
Any other suggestions? 02 sensors? Engine mounts? Just curious as to what else tends to be problematic at interval service dates?
- Oil change
- Transmission pan drain
- New brake pads, rotors, and calipers
- Brake fluid flush
- New Monroe Quickstruts in front and back
- New LCA's, Tie rod ends, and end links
- New inner tie rods
- New fuel filter
- New PCV valve
- Throttle body cleaning
- New tires
- New Platinum (OEM) spark plugs
- Front end and rear end alignment
sounds like one hellova find! You gonna post pics? How much did you "snag" it for? lol.
As for the maintenance, youve already done more than enough. Know that old saying, dont fix it if it isnt broke! Try and stick to that! You replaced most of the parts that wear out if they needed it or not. The fluid flushes were good though.
Are you experiencing any issues or you just throwing more money into it?
Either way great find. I know you'll enjoy!
Also, wanted more of a foot print so I found a set of 17" 2001 Maxima wheels (paid $180) and are having them reconditioned for $250. Not bad since they normally sell for $175 each. Finally, the tires were shot so I picked up a set of take off Michelin Energy's for $400 to mount on the new rims. My wheel set up will be done tomorrow.
As far as fluid changes, everything else was just general maintenance on a vehicle this old. The throttle body had a nice build up of carbon deposits. The PCV valve was gunk'd up. Spark plugs were OEM but couldn't confirm how old they were. So new OEM platinum's were put in. To top it off, the Max was thirsty for Mobil 1 high mileage full synthetic oil with a Mobil 1 filter.
The savings of labor and heavily discounted parts didn't put too much of a dent in my bank account, especially for a car 15 years old. Considering I only paid $2750 for it, I'm not complaining. It's just my daily driver to and from work anyways.
I do have a question though regarding the IACV. After my tune up and TB cleaning, I noticed a higher idle RPM when cold and warm. I did happen to adjust the loose throttle cables to take up some slack so I backed off the tightness a bit to correct it. It was still idling around 900 so I adjusted the black screw the contacts the throttle cable linkage. Got it down to 750-800. What's normal for idle for our Max's? Also, is there a better procedure to adjust idle RPM's after a tune up?
There's no rear alignment on a '98....looks like you got a lot covered. If your starter clashes the was a lube issue on the original, and depending on where you live, the subframe rusts out and detaches from the lower rad support....
I'm definitely enjoying the Maxima. Wish I had picked one up years ago. Didn't realize how reliable this generation was.
Lakersallday24
03-20-2024 11:22 AM
morteljc
10-19-2015 10:47 AM
Finkle
09-27-2015 09:53 PM
