clock flickers when engaging turn signal
I've noticed for the recent past that the clock my 99 I30 will brighten or flicker when I engage the turn signal. Is my alternator on its way out or is this just a bad voltage regulator which I believe can be replaced on the alternator. Any ideas? Check out the video to see what I mean
there's a wire that controls the brightness of the light, and it is toggled with the headlights/corner lights. has anyone had your interior apart at any point? and yea definitely check the alternator and battery first
Back when I owned my 1995 Maxima, it did the same thing when I bought it. The car did it for months and months and the alternator did go bad. But I wasn't certain the two issues were related or not.
Well if you wanted to try something cheaper than buying an alternator, you might try replacing the headlight stalk (just with a junkyard one) but i think that alternator needs some testing
Alternator problem, not - electrical issue instead
I had a similar problem. Check that your electrical connections from the positive battery terminal to the fuse block behind the battery are all clean (ie no corrosion or oxidation). Take them all apart and clean them to make sure they have good clean connections. Also clean the ground to chassis right behind the battery. I thought I had an alternator problem, but that wasn't the case. The power supply was problematic because of some corrosion and oxidation. That positive battery clamp has a lead that slip on and sends power to the fuse block right behind the battery. Clean all that up.
I thought my problem was my 1 year old Autozone alternator based upon what I read here. That was not correct. Once I cleaned up those connections my problems went away. Good luck. Rich
06-06-2017 02:01 PM
DC_Juggernaut
09-28-2015 04:07 PM
