Gas pedal "sticks" after sitting long periods
Old 01-22-2013, 04:08 PM
stromm's Avatar
Totally weird. I've never had a car (almost 30 years of them) do this.
It's only when "first" pressing the pedal after starting the car and it's sat for hours. Usually over night, but I had it happen when I went to go to lunch at work.
I can't see anything rubbing.
It really feels like it's in the pedal though.
I have to hit the pedal with enough force that if the car is in gear, it'll jump forward. But then it never catches. Not even if I use my foot to pull up on it.
Any suggestions?
stromm is offline
Old 01-22-2013, 07:42 PM
DennisMik's Avatar
The cable between the pedal and the throttle body consists of an outer casing with a cable in the center that moves. There may be rust forming inside. This is what usually happens to parking brake cables that "freeze up".
DennisMik is offline
Old 01-25-2013, 10:53 AM
iDuty's Avatar
It's worth noting that a similar symptom can be caused by accumulations around the throttle butterfly. You can clean this area effectively yourself, I am sure there have been many threads about it.
iDuty is offline
Old 01-26-2013, 04:47 PM
stromm's Avatar
Wow, that's a great place to look. I should know better as I have to clean my '94 Impala SS's every 10k or so.
I'll try that and then look at getting a new throttle cable.
stromm is offline
Old 01-26-2013, 06:32 PM
kasso28's Avatar
The pedal itself also has a return spring that might be worn out. Theres also a counterweight down there, but I'm not sure if its there to help the pedal return or go down.
kasso28 is offline
Old 01-26-2013, 07:51 PM
billmus86's Avatar
throttle body.. clean it and youll be good to go
billmus86 is offline
matts95max
09-09-2023 01:52 AM
03-12-2020 12:06 AM
captchaos
03-15-2016 12:18 PM
NissanNismoZ
09-12-2015 07:30 AM
slowlifer
09-08-2015 05:53 AM
Quick Reply: Gas pedal "sticks" after sitting long periods
