rear koni shock help
Old 01-11-2013, 08:30 AM
NABU6's Avatar
On the rear shocks there there is a metal ring that comes with the spring perch. Were does this go?
NABU6 is offline
Old 01-11-2013, 11:44 AM
Quickywd01's Avatar
It barely slides over the strut body and rests on the notch of the strut. The GCs for Konis have this notch machined out that sits on top of this ring.
That ring is all you need. You don't need those spring perches that Koni supplied. The rear GC collars have a groove machined out of the bottom and that rests snugly on the ring.
Are you using a ground control setup?
Quickywd01 is offline
Old 01-11-2013, 01:08 PM
I'm nutty for Nissans
JSutter's Avatar
A circlip sits in one of the 2 grooves in the strut body. The ring sits on the circlip. The spring perch sits on the ring.
JSutter is offline
Old 01-11-2013, 03:00 PM
njmaxseltd's Avatar
I can imagain the Konis didn't come with instructions?
njmaxseltd is offline
Old 01-11-2013, 07:19 PM
NABU6's Avatar
No, not at this time. Maybe in the future. Running them with H&Rs.
NABU6 is offline
Old 01-11-2013, 07:21 PM
NABU6's Avatar
Thanks for this answer, that is the way I thought, but wanted to be sure.
NABU6 is offline
Old 01-11-2013, 07:24 PM
NABU6's Avatar
They did, but they are a little difficult to understand.
NABU6 is offline
Old 01-12-2013, 10:32 AM
JSutter's Avatar
Konis instructions are like Hieroglyphics.
JSutter is offline
matts95max
09-09-2023 01:52 AM
AcuraLegend
10-17-2016 08:47 PM
AcuraLegend
09-22-2015 04:22 PM
Violator
09-09-2015 10:14 AM
Quick Reply: rear koni shock help
