someone please help me
http://www.permoveo.ltd.uk/tabid/122...n/Default.aspx
p0512 bad grounds check them all ,, (worst case get a 8 or 4 awg wire attach it to the long bolt of the starter to the ground of the battery ..
p0511 iac valve ( idle air control valve issue) this is random check it first and there is a way to check it or do what I did .. remove the intake clean the crap out of the throttle body and maf sensor and try a Lil sea foam my issue cleared up after some driving .. and make sure your using 93 octane ..may not b related but it makes a huge difference in performance ..
I hope this helps every scenario is different
P0140 (0512) REAR O2 SENSOR
P0137 (0511) REAR O2 SENSOR
Post 7,506 http://forums.maxima.org/4th-generat...ml#post8146357
i would doubt that it is a cali spec because the production date is 07/97 and i live in canada and car was bought in canada. I also looked under and saw 2 o2 sensors in the y pipe and 1 right after the cat.. but the cat looked like it had a spot for a 02 sensor in it but there was a bolt there.. reason being is prolly that cat was made for cali and non cali spec and of course the cat is aftermarket bosal
is that right?? i didnt think it mattered unless u were s/c or turbo.
Your car - non California
California cars and 2001 and later
ok thanks for posting the diagram it makes sense now.. the code is there because i have a little exhaust leak right before the rear O2 sensor at the flange where the cat meets the mid pipe. ill get that sorted out and a new knock sensor and my CEL should go off.. Fingers crossed!
