If you're pulling your IACV...
Old 12-03-2012, 02:10 PM
DBear's Avatar
If you're planning to pull your IACV to clean it, or even better replace it, do me a favor and compare it to this: http://s397.beta.photobucket.com/use...tml?sort=6&o=8 I'm suspicious of the little gasket like pieces near the tip that look like they're coming off, but they may be some kind of compression device to make a tighter seal. I'm getting an occasional issue at idle, but this is too expensive a part to just throw at it...
DBear is offline
Old 12-03-2012, 02:28 PM
carsnwomen91's Avatar
How much apart is this? It doesnt look like a 4th gen iacv :S
carsnwomen91 is offline
Old 12-03-2012, 02:35 PM
tigersharkdude's Avatar
DBear, I just took mine off and cleaned it last week. I dont remember seeing anything like that "gasket thing"
tigersharkdude is offline
Old 12-03-2012, 04:42 PM
MAXIMA_STYLE's Avatar
Someones a little too paranoid...
MAXIMA_STYLE is offline
Old 12-04-2012, 01:02 PM
DBear's Avatar
If you pull the IACV, this part bolts onto the triangular plate. The tip is what you see through the hole if you look at the engine side of the IACV.
DBear is offline
Old 12-04-2012, 01:51 PM
cjanderson3's Avatar
Yea that's about what mine looked like. I just pulled it the other week to clean it. I say if your car still starts fine don't worry about it
cjanderson3 is offline
Old 12-04-2012, 07:28 PM
delacruz_17's Avatar
I took mine off today and cleaned it up a little:
delacruz_17 is offline
Old 12-04-2012, 08:10 PM
Fakie J Farkerton's Avatar
Agreed. I cleaned mine just because and actually ended up with problems after I put it all back together. Good times.
Fakie J Farkerton is offline
Old 12-04-2012, 08:15 PM
CrazxyDominican's Avatar
what year is that maxima.. my iacv looks nothing like that
CrazxyDominican is offline
Old 12-04-2012, 08:19 PM
What kind of problems did you have and how did you fix said problems?
Old 12-05-2012, 12:25 PM
DBear's Avatar
Thanks delacruz. It looks like you've got the same thing sticking up around the tip. It must be something like a lock washer.
DBear is offline
Old 12-05-2012, 01:40 PM
I swapped to a 3.5 shortly after, but my next step would have been shopping on the org, or junkyard, ect.
Old 12-05-2012, 04:24 PM
ShocknAwe's Avatar
Guys, if you look at your IACV, the part facing the firewall has a piece that can be removed that has a light-brown colored plastic around it. This is the plunger and actually if you take this off and turn your keys with just the plunger connected you can double check to see if it is working together IE going out when you turn the key and back in when you turn the car off. Yes it does have a gasket if I remember correctly
ShocknAwe is offline
Old 12-05-2012, 06:37 PM
TravisCadello's Avatar
Yeah my IACV is NOTTHING like that lol idk what ya are working on.
TravisCadello is offline
Old 12-05-2012, 11:54 PM
ooo i see now... yaa i'm not touching that lol i have a spare iacv anyway and they're so easy to get at a junkyard i just dont care much
Old 12-06-2012, 04:37 AM
Fatboy98maxima's Avatar
interesting hummm
Fatboy98maxima is offline
Old 12-06-2012, 05:34 PM
JAmerican's Avatar
What's the occasional issue? Check my sig for a High Idle thread. It may be helpful for eliminating a potential idle issue that plagues 4th gens.
JAmerican is offline
Old 12-07-2012, 02:18 PM
DBear's Avatar
It's been a little rough for a while. I think the idle may be a bit low, but I haven't bothered with it yet. But recently the idle has started to drift up occasionally when I'm stopped. It's normally around 600, but will drift up to 8 or 900, then sometimes drift back down, depending on long I'm stopped. I've been thinking it might be the ECTS going bad, so it thinks the engine is cold when it's warm and increases the idle, but that's just a guess. I just skimmed through your thread. I have cleaned the TB and the IACV, but I didn't pull the TB to do it, I just came in through the front with some TB cleaner. I'll spend some more time going through that thread, thanks.
DBear is offline
06-06-2017 02:01 PM
HerpDerp1919
09-29-2015 02:02 PM
09-27-2015 08:37 AM
Quick Reply: If you're pulling your IACV...
