Fuel Pressure Regulator - Video or Guide?
Looking for a video or any other available guide to changing the fuel pressure regulator on a 4th gen maxima.
My issue is similar to many other maxima owners issues. If I don't start the car for more than a day it takes a few cranks to start it. As long as I start it every 12-15 hours it starts without issue.
I had the same problem twice. Once the vaccuum hose was torn. The second time the fuel line going to the FPR was slightly loose causing the fuel rail to very very slowly loose pressure after sitting. There is also a 90 cent o-ring which could be the culprit.
I don't think a video is needed for this as it is right in front of you as you open the hood. As for ruling this part out, if you crank your car and it starts up and dies right away, then the FPR could be the cause ONLY if you need to keep your foot on the gas to keep it on for a few seconds. If otherwise, your problem is somewhere else.
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
