Rebuilding 5 speed trans *pics of mystery piece added*
I am rebuilding my 5 speed transmission out of my 95 maxima. I took out the input shaft, main shaft and differential, then i cleaned up and found a round roller thing with a square rod about 2 to 3 inches long. Anyone know where this goes? I looked on the fsm but i am not seeing it. Thanks for any and all help!
Is this what you're looking for
That's the diagram of the standard differential I found on nissanpartszone. The MT FSM you're looking at probably has the diagram of a non-slip differntial. Your square rod is most likely the shaft mating the pinion gears within the differential.
EDIT: The 1995 MT FSM only shows the non-slip differential. This 1996 MT FSM shows both.
Just had my 5 spd out and apart last night. I didn't break down the gear stacks or get into the differential but I didn't come across the part you are describing or any square shafts at all. It doesn't sound like part of any of the gear shafts or fork shafts or the reverse brackets in the transmission section. Everything there was round shafts, *****, springs, roll pins. The reverse idler shaft is round and 5"-6" long, has a gear and a heavy weight at one end. I would have to agree with jholley that it might be the shaft in the non-limited slip differential. That is the more common 50A transmission/diff versus the limited slip 50V. You can determine which you have by looking at the metal tag on the passenger side of the firewall. If you have the 50V you'd have a viscous coupling whereas the 50A you'd have that square shaft connecting the gears.
1/4" square and 2-3" long. Sounds like a key for a gear. Did you remove and gears from shafts before you found that part?
I didn't remove the gears from the shafts. I don't know where it came from. It goes into the back of a round thing. I guess I am gonna take a deeper look into the fsm when i get home. I knew something like this was gonna happen.
Nealoc, if you figure out what he is talking about, I'm curious to know .... I can't even picture where in our trans that would be from .... the detent pins are round so, about 1/4" thick, but only 1/4" long so. I have no idea unless it's a keyway pin, but to where?
Pics of the item found. Not anything I recognize as a transmission part, but maybe I'm losing my mind? I've been inside a bunch of these transmissions over the years.
Anyone recognize this?
So it is part of the sensor that goes in from the outside of the transmission? My sensor was in a couple pieces so I wouldn't know. As long as its not internal I'm all set. Thanks everybody for the help.
knight_yyz
11-01-2015 01:34 PM
Pied
09-26-2015 03:29 PM
