'97 Infiniti I30 with CEL Code 0505???
Old 10-02-2012, 10:44 AM
sanford7575's Avatar
'97 I30 (yep, same one with the strut problems posted earlier), received a CEL yesterday whiile trying to test tranny mount by revving engine with foot on brake to see engine movement, wife said that "tranny was acting funny on Saturday" so I thought I'd check.
Anyway, while doing this the engine stumbled badly a couple of times, the CEL came on, and the engine actually stalled. I quickly pulled the codes and got 0505. I checked the site, and 0505 means "no fault found", so I'm in the clear, right?
But if I'm in the clear, why would I receive a CEL in the first place?
I then googled Infiniti I30 0505 error code, and a million posts pop up about the infamous 5th gen iac issue? Why the hell would a 4th gen 0505 mean nothing and the 5th gen 0505 mean iac / fried ecm?
I don't think there's anything wrong with my IAC because my idle is fine and the car seems to run fine. However, it did stumble and stall during my mount test, and I did get a CEL. Wife drove the car to work today with no reported issues, and no reappearence of the CEL?
Can I get a definitive explanation on the 0505 CEL for a 4th gen? Also, any suggestions on next steps??? My apologies in advance guys, I guess this is my week to be a dumbass!
sanford7575 is offline
Old 10-02-2012, 11:43 AM
P0505:
http://www.boredmder.com/ecucodes/in...1997&DTC=P0505
ChrisMan287 is offline
Old 10-02-2012, 01:01 PM
Thanks, but the flashing CEL code was 0505 which comes up not found.
Any other suggestions...
Old 10-02-2012, 10:05 PM
DennisMik's Avatar
The 0505 gotten by counting the blinking CEL lamp is a mystery to me. Last year there were a lot of posts on tis, but the definition is what you read - no fault. Why it come on, I don't know and I never read anything to answer this.
Then there is the P0505 DTC you get from using an OBD reader. It is a completely different critter from the blinking 0505. P0505 is a 0205 blinking CEL lamp code.
You have to understand Google searches. It will give you a search hit based on a partial match. If you do the Google search again, look at the results again. It had the letter P in front of the 0505. Then try the search with quote marks around the 0505, i.e., "0505". The results will be different. The quotes mean exactly this, not partially this.
DennisMik is offline
litch
123
01-04-2024 07:01 PM
trsandrew
04-08-2016 06:45 PM
maxinout93
10-31-2015 02:04 AM
trsandrew
10-25-2015 02:47 PM
Quick Reply: '97 Infiniti I30 with CEL Code 0505???
