95 max interior dome light dead
I had a dome light blow. So i replaced the bulb, and still no go.
All other interior lights and exteriors work; fuse is good.
Any clue of the culprit other than a broken wire in the roof?
Have you checked fuses? If you blew the fuse the step lamps (the lights in the door) will not work. Get a volt meter or a test light and see if you have power on one side of the light bulb all the time, regardless of the dome light switch position. The dome light switch is 3 position - off, on with door, and always on. The center position is the "on with door" position.
carguy96
20
02-06-2021 06:21 AM
vingodine
45
05-21-2016 12:46 PM
Slamrod
04-10-2016 05:24 PM
King_Ten_Ahead
09-30-2015 04:27 PM
rbaker100
08-28-2015 08:11 PM
