lowering my car
Old 08-31-2012, 07:12 PM
  #41
eddie982's Avatar
Probably the Teins They sound perfect for you now.
eddie982 is offline
Old 08-31-2012, 08:10 PM
  #42
ibracey's Avatar
Originally Posted by eddie982
That's pretty close to what H-Techs offer.
i found a guy on CL selling some ebiach lower springs that are that drop for 100 bucks but i dont have the money for new shocks and struts now
ibracey is offline
Old 08-31-2012, 08:26 PM
  #43
T_Behr904's Avatar
Originally Posted by alexx0108
Comfortable ride? Stick to stock. Thats the most comfortable ride.
Or buy a Cadillac...
T_Behr904 is offline
Old 09-01-2012, 05:59 AM
  #44
MAXIMA_STYLE's Avatar
Im on progress and illuminas... kinda stiff not a bad ride but ill be selling shortly...going buy my buddies d2s today
MAXIMA_STYLE is offline
Old 09-01-2012, 06:43 AM
  #45
dwapenyi's Avatar
Anyone on here have coilovers and drive on NYC roads? Or is the assumption that all roads are like racetracks to fully enjoy COs?
dwapenyi is offline
Old 09-01-2012, 07:11 AM
  #46
GGENIUS's Avatar
i live in trenton and have been to NYC plenty of times so i know that the roads are very similar. havent been taken care of for what looks like a hundred damn years. people around here have to avoid certain streets, routes, ect when they go that moar low
GGENIUS is offline
Old 09-01-2012, 03:56 PM
  #47
Thaboywonder6588's Avatar
I was thinking about getting some H&R Springs and illuminas
Thaboywonder6588 is offline
Old 09-01-2012, 10:00 PM
  #48
mayur914's Avatar
You should buy mine then. Ill throw in some free camber bolts once I get my coilovers
mayur914 is offline
Old 09-02-2012, 08:35 PM
  #49
Price?
Old 09-02-2012, 08:45 PM
  #50
WesCTR's Avatar
Coilovers. coilovers. coilovers. damn.
WesCTR is offline
Old 09-03-2012, 05:20 AM
  #51
dwapenyi's Avatar
OK. That's what I was thinking.
dwapenyi is offline
Old 12-27-2012, 12:05 AM
  #52
Quanie's Avatar
Im lowered on H&R Sports spring and Illumina's on 07 stock 18's, and i still can feel every bump in the road.
Quanie is offline
Old 12-27-2012, 07:44 AM
  #53
cashoit's Avatar
Im going to advise against the camber bolts.
Most alignment shops just read the computer for Nissan alignment specs. Nissan says you are not supposed to adjust camber. When the shop sees this they dont adjust the bolts.
I had camber bolts from Summit Racing. They kept backing off and screwing up my alignment. After the 3rd attempt i thought about it and asked the guy if he adjusted camber bolts. He didnt even notice they were there!
I promptly took off the cambers and now the car is straight as an arrow!
cashoit is offline
Old 12-27-2012, 07:53 AM
  #54
cashoit's Avatar
I have Tokico blues and they straight. I was thinking about switchin to illuminas but in terms of dampening they seem about the same. Or what setting do u have the illuminas set to? I have hrd on setting 2 its stock soft
cashoit is offline
Old 12-27-2012, 09:32 AM
  #55
cjanderson3's Avatar
Camber bolts aren't completely necessary, but you will wear down the insides of your tires if you lower without them. When you shorten the spring and strut assembly (as in lower the car) the tires don't just move straight up. They are going to move around an arc, with the pivot point being somewhere around the control arm. So the lower you go, the more negative camber you get and the more you start to wear the insides of your tires.
...food for thought
cjanderson3 is offline
Old 12-27-2012, 10:37 AM
  #56
cashoit's Avatar
Agreed. thats why i had gotten the bolts in the first place.
The way my mechanic had initially installed the bolts. the fronts were crazy negative!
I have removed and realigned now everythin in spec. but ima keep an eye out for abnormal wear.
I do remember doing research and ppl saying that the bolts were necessity if you go 2"+ drop. Im thinking for my mild drop its fine w/o the bolts.
cashoit is offline
Old 12-27-2012, 04:49 PM
  #57
Quanie's Avatar
I have the fronts on 3 and the rears on 5. I cant even carry like 2 people in the back because it rubs when i hit a bump.
Quanie is offline
Old 12-30-2012, 05:30 PM
  #58
CMax03's Avatar
Sounds like you might have extreme wider tires or spacers......you may need to roll your fenders......or limit how many people you ride in your car....Are you a taxi??????
CMax03 is offline
Lakersallday24
06-16-2019 01:35 AM
twotonezed
08-16-2015 08:10 PM
soon2ownmax
08-13-2015 02:19 PM
classymax420
08-06-2015 06:35 PM
laparka66
08-06-2015 09:36 AM
Quick Reply: lowering my car
