Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 08-16-2012, 03:03 PM   #1
Points: 2,937, Level: 33
Points: 2,937, Level: 33 Points: 2,937, Level: 33 Points: 2,937, Level: 33
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
deloa84 Unshapenraptor2
P1400 EGRC code gone on my 95 ecu swap!!!! YAY!!!
What is going on orgers.. I just wanted to post some finding I found when I did my ecu swap from a 99 to a 95 in my cali spec emissions car.
Now, I used whlimi's excellent writeup he did 99 to 95 ECM swap a Success!. It was followed to the letter. One of the codes I got was the P1400 or EGRC Solenoid Valve. This was obvious since the EGR design in the 99 cali is different from previous models.
As I was looking through the FSM of the 99 as well as some of the threads regarding the code P1400, I came across the Swirl Control Solenoid valve. It caught my attention because it looked very simmilar to the EGRC solenoid valve that the 95 ECU uses.
Here is a pic of the Swirl Control Valve
Click the image to open in full size.
Here is the pic of the EGRC solenoid valve.
They look similar Right?
I even looked at the wiring setup for both. I noticed that they are both in the fuse block number (17) and that they use the same type of connector (circled in red). As I was reading throught for the operation, diagnosis etc, they both read the battery voltage and they both work on a vacuum design.
So this lead me to move the light blue/yellow (L/Y) cable on my 99 in pin 71 over to pin 103 in the 95 ECU. The pin on 71 was smaller so I had to use the pin from 117 (fuel pump wire) which was cut in the previous step in the ecu swap.
I checked this morning and NO P1400.....
I also passed emissions as well...
Let me know what you guys think...
deloa84 is offline   Reply With Quote
Old 08-16-2012, 03:56 PM   #2
Points: 2,848, Level: 32
Points: 2,848, Level: 32 Points: 2,848, Level: 32 Points: 2,848, Level: 32
Activity: 4.3%
Activity: 4.3% Activity: 4.3% Activity: 4.3%
Nice. Gonna try this tonight
Roosky is offline   Reply With Quote
Old 08-16-2012, 06:48 PM   #3
Points: 8,020, Level: 60
Points: 8,020, Level: 60 Points: 8,020, Level: 60 Points: 8,020, Level: 60
Activity: 32.4%
Activity: 32.4% Activity: 32.4% Activity: 32.4%
__________________
AZ Maximas
schmellyfart is online now   Reply With Quote
Old 08-16-2012, 07:40 PM   #4
Activity: 0.7%
Quote:
Let me know how it goes
Old 08-17-2012, 09:06 AM   #5
Points: 11,510, Level: 70
Points: 11,510, Level: 70 Points: 11,510, Level: 70 Points: 11,510, Level: 70
Activity: 2.2%
Activity: 2.2% Activity: 2.2% Activity: 2.2%
Send a message via AIM to venompwr2
Did you use an ecu with the same type of transmission? I have a 99 with some emissions codes because I put an engine from a 95 in it and left all else alone, so there are some things which arent connected because th 95 motor doesnt have them. However, I have a 95 auto max as well and was pondering the swap but really don't want any lights on for a mismatch tranny either.
__________________
1999 Maxima Black on Black SE 5spd Supercharged
2006 Nissan Xterra
2008 Buell Lightning XB12Scg | 1980 HD Sportster XLH
venompwr2 is offline   Reply With Quote
Old 08-17-2012, 09:50 AM   #6
Activity: 0.7%
I used a 95 ecu manual and I have a manual. As long as you put everything that was on the 99 onto the 95, you should be ok. The biggest thing would be definitely be the EGR.
I think the only issue you may get putting an auto ecu in a manual is a slightly higher rpm?? Not sure if it throws a code, it probably does.
Old 08-17-2012, 03:55 PM   #7
Activity: 4.3%
so far so good. good job!
Old 08-17-2012, 09:10 PM   #8
Activity: 0.7%
awesome!
Old 08-17-2012, 11:10 PM   #9
Activity: 4.3%
Now I just gotta get either a 95 manual tranny ecu or a 96-98 purge valve set up to get rid of P0443, since I'm running a 98 fed manual tranny ecu in a 99 cali car :/
Old 08-17-2012, 11:26 PM   #10
Points: 7,129, Level: 55
Points: 7,129, Level: 55 Points: 7,129, Level: 55 Points: 7,129, Level: 55
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
I got 98 Auto ECU, $70 shipped. Sorry for sale whoring
eddie982 is offline   Reply With Quote
Old 08-18-2012, 06:06 PM   #11
Activity: 0.7%
Good luck man sounds like you got some work cut out for you haha
Old 08-19-2012, 05:18 PM   #12
Points: 7,405, Level: 57
Points: 7,405, Level: 57 Points: 7,405, Level: 57 Points: 7,405, Level: 57
Activity: 0%
good write up was just going through fsm i also have a 95 ecu in my 99 since the nats system went haywire also did ever get the code for the o2 sensor if so how did you get rid of it
96sleepergle is offline   Reply With Quote
Old 08-19-2012, 08:39 PM   #13
Activity: 0.7%
Quote:
Still working on the O2 code. I remember reading something being about the way it is grounded... I will look at it sometime when I get a chance.
Old 08-20-2012, 01:12 PM   #14
Activity: 0%
I've switched the pins on the 02 sensor added o2 simulator ill see what happens next 100 miles of driving of the code comes back
Old 08-20-2012, 03:10 PM   #15
Activity: 0.7%
Keep me posted...
Old 08-25-2012, 06:49 PM   #16
Activity: 0%
Keep me posted...
the code came back so im going to try something different could be the heater wire but have you tried any other than what was recommened
Old 08-25-2012, 09:26 PM   #17
Activity: 0.7%
I have not... I checked and I have not gotten the P1400. You should check continuity between the wires see what it reads...
edit... I am guessing you were referring to O2 code. My mistake...
Old 08-26-2012, 05:44 AM   #18
Points: 12,904, Level: 74
Points: 12,904, Level: 74 Points: 12,904, Level: 74 Points: 12,904, Level: 74
Activity: 0.9%
Activity: 0.9% Activity: 0.9% Activity: 0.9%
Interesting find! Good work, I have a 99 fed 5spd, with the vq35de swap, not completely wired up yet, and If I get a 95 ecu I'll be trying this one!
Maximeltman is offline   Reply With Quote
Old 08-26-2012, 09:16 PM   #19
Activity: 0%
yes the o2 sensor kind of figured out the problem just might have to buy the o2 sensor in the cat im using simulator from my lc-1 innovate motor sports what ive read from fsm the volt range needs to be 0.0-2.2 so i programed the lc-1 to that range lets see what happens
Old 08-27-2012, 01:17 PM   #20
Activity: 0%
The 95-97 voltage is 0.0-1.0 99,s is 0.0-2.2 mv this is why the code keeps piping up you .have to convert (,change) the o2 to 95-96
Old 08-27-2012, 01:54 PM   #21
Activity: 0.7%
Or throw in a resistor? I might try that resistors are cheap at RadioShack and even cheaper when my bro works there and can get me a discount lol
Old 08-28-2012, 12:53 PM   #22
Activity: 0%
I don't think it would work because a resistor cant imulate change in voltages remember the range 0-2.2 mv and its for monitoring the cat so the only route is to change the sensor or try to get the innovate lc-1 to work which I'm trying to but its tricky
Old 08-30-2012, 12:51 PM   #23
Activity: 0%
Code came back going to put proper sensor to solve the problem have emissions testing coming up
Old 08-30-2012, 02:31 PM   #24
Activity: 0.7%
Hmm.. good luck man.
You know what's really strange. I let my brother use my car for him to go to work since I was out of town yesterday, came back and I had no CEL's. I asked my bro if he had cleared the codes ( I don't think he knows how) and he said no.
I had P0136 O2 and another code related to the O2s as well as a knock sensor code. I checked to see if the bulb was burnt out but no its fully functional. I will check to see if any ghost codes are present (possibly knock sensor?) and report back...
Old 09-06-2012, 01:27 PM   #25
Activity: 0%
here's a link for the p0136 code
96 ECU in a 98 - getting rid of P0136 (long)
Old 09-06-2012, 03:49 PM   #26
Points: 12,036, Level: 71
Points: 12,036, Level: 71 Points: 12,036, Level: 71 Points: 12,036, Level: 71
Activity: 38.2%
Activity: 38.2% Activity: 38.2% Activity: 38.2%
maxstyle96
I may have to try this when i do my 97 ecu swap... i got a 97 fed spec engine in my 99... my lights been on so long it burnt out LOL
MAXIMA_STYLE is offline   Reply With Quote
Old 09-06-2012, 06:47 PM   #27
Activity: 0%
Quote:
same here my check engine light been on for months but going to try switching the ground when i put the proper sensor in this weekend you need to get a 95 ecu produced from 8-95 so you wont have the code for fuel pump, purge valve ect...........
Old 09-16-2012, 07:30 PM   #28
Activity: 0%
Ok guys think ive solved the po136 code for people running 95 ecm in a 99 cali spec unpon reading the fsm for 99 cali spec you dont need to switch pin 107 to 105 because there are 2 sensors at 107 and 105 that monitor front and rear banks, so what i did i just switched the signal wire around moving pin 57 to 56 and 56 to 57 since thursday sept 13th ive driven the car about 80 miles and at least 10 driving cycles so far no ghost codes of any kind ill keep every one posted
Old 09-24-2012, 07:26 PM   #29
Activity: 0.7%
Sweet! I will get at this as soon as I can. School is in the way... Thanks for the info!!
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
