Low Compression while engine is running
Old 07-12-2014, 05:03 PM
man_flannel's Avatar
I have a 1995 Maxima and have a misfire on the number 5 cylinder (back driver side). I know the coil is good because I swapped it with another cylinder and still had a misfire on number 5. Nearly positive that the fuel injector is good because it was changed less than a year ago. Plug is good also. So fuel and spark is good.
That leaves compression. If I disconnect all the coils and just turn the engine over with the starter, number 5 cylinder has over 120 psi, which should be fine. However, If I reconnect all of the coils and have the engine running on the other 5 cylinders, number 5 cylinder only has 30 psi, which would cause the misfire.
I'm thinking I have a valve problem, maybe a weak spring or a sticky valve or something. If it was bad piston rings I wouldn't be getting the 120 psi when just cranking it with the starter.
Any advice/thoughts is greatly appreciated. Thanks.
man_flannel is offline
Old 07-12-2014, 05:07 PM
Chad_m's Avatar
Have you squirted a little oil into the spark plug hole and then rechecked it?
Chad_m is offline
Old 07-12-2014, 05:12 PM
No but that does sound like a good idea. Thanks for the input
vybz05
12-10-2015 07:38 PM
schmellyfart
09-25-2015 04:47 PM
Slamrod
09-03-2015 07:38 PM
MaximaDrvr
08-19-2015 08:20 PM
Quick Reply: Low Compression while engine is running
