HELP : Rounded off the tensioner pulley bolt
Old 09-10-2012, 10:44 AM
MikesChevelle's Avatar
I was replacing a belt that sheared off on my 98 and was going to loosen the tensioner bolt (not the adjustment one) and its rounded off. Its right next to the frame so I cant get a socket on it, only a wrench.
All I can think to do is get a file on it and make some new sides??? any other thoughts????
MikesChevelle is offline
Old 09-10-2012, 10:48 AM
maxfever1987's Avatar
loosen the adjustment screw on top completly and push thenpulley all the way, than take off the 2 12mm bolts at the bottom and the one 12mm bolt at the top, once you do this the entire pulley assembly comes off from the engine block, once you have it off from the engine you can try filing the bolt of see if a socket will fit on it,
maxfever1987 is offline
Old 09-10-2012, 10:56 AM
i cant, the belt sheared off so I never loosened the tensioner in the first place. I can looses the adjustment screw all I want but the pulley wont budge up or down to get to the bracket bolts
Old 09-10-2012, 10:59 AM
you can tap it with a hammer and it will move slightly, just tap it continously it will move i have done this several time for ppl who rounded their bolts before, rather than an open wrench an 14mm gear wrench worjs better in areas like this
Old 09-10-2012, 11:42 AM
been beating on it for a half hour and it hasnt budged
Old 09-10-2012, 12:24 PM
you should try the gear wrench its a ratcheting wrench,
Old 09-10-2012, 12:35 PM
well neither works on a round bolt head silly
Old 09-10-2012, 12:52 PM
ShocknAwe's Avatar
I was just at the pull-a-part today and there was a belt tensioner sitting in the engine bay I could have grabbed for ya. I know you dont want to hear that lol but helluva coincidence
ShocknAwe is offline
Old 09-10-2012, 01:00 PM
Just the tip.
JNCoRacer's Avatar
Vise grips.
JNCoRacer is offline
Old 09-10-2012, 01:07 PM
haha
Some times using a 12 point wrench might be helpful rather than a 6 point, you must have rounded it off real bad,
Old 09-11-2012, 07:39 PM
Trini Boom's Avatar
Originally Posted by JNCoRacer
Vise grips.
Trini Boom is offline
Old 09-11-2012, 10:15 PM
maxed_out_99's Avatar
go to auto zone and tell them you need a bolt extractor to rent. remove the pully and remove the nut on a bench, table whatever you have then toss it over your shoulder and replace it
maxed_out_99 is offline
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
knight_yyz
11-01-2015 01:34 PM
RealityCheck
10-02-2015 06:34 PM
Quick Reply: HELP : Rounded off the tensioner pulley bolt
