The definitive radiator core support thread
Old 08-07-2012, 07:51 PM
tigersharkdude's Avatar
As many of you may know the radiator core support is a known "weak point" on the A32 chassis. This is an extremely common issue among A32's from "wet" states. This thread will address a number of key points with this issues
1)Signs of a bad radiator core support
2)How to replace said radiator core support
3)And why you shouldnt use a cheap radiator core support
I:
lets start off with spotting a failing core support (NOTE: The images shown are of very, very badly rusted supports) .
II:
we move on to How To replace the core support and what is the proper parts to be used and where you can purchase them.
To correctly replace the core support, the old unit will need to be cut out and the new unit will need be be bolted and welded in place..This job is definitely not one of the easier things to do an A32 and will likely need to be done by a professional or a fairly knowledgeable DIY mechanic with access to air tools and a welder.
Their are two common methods to to replacing the core support; one is replacing just the lower support (under the radiator) and the other is replacing the entire front core support. Either of these parts can be sourced at your local Nissan dealer or through a reputable online dealer such as Courtesy Nissan Parts.
PARTS
  • This link takes you the Front Apron & Radiator Core Support diagram and parts list LINK
  • The part number through Courtesy for the entire support is 62500 and HERE is a link.
  • The part number through Courtesy for the lower support is 62530M and HERE is a link
I'm not going to post all of the info in the following threads ... please follow the links for more information
JSutter - How to: Radiator support on life support.... fixed!
95naSTA - Lower Radiator Support Replacement Pics
http://forums.maxima.org/4th-generat...nt-photos.html
III:
we will move on to why you should buy an OEM core support and not a cheap piece off of ebay or rockauto. This is one of those things that "if it sounds too good to be true, it probably is"...meaning that $50 coresupport on ebay may sound like a steal of a deal right now, but 3 months down the road when you notice your engine cradle is sitting 3 inches off the ground and you have to pay to do all of this work again, you will wish that you had just spent the extra money to begin with because in the long run an OE piece is going to be the cheaper AND better investment.
I will let the images speak for themselves
If you believe anything should be added or changed please let me know.
tigersharkdude is offline
Old 08-07-2012, 07:54 PM
ShocknAwe's Avatar
look at you helping people out and playing nice. Good thread though
ShocknAwe is offline
Old 08-07-2012, 10:14 PM
Amerikaner83's Avatar
So glad my car is a WA only car..I shouldn't have to worry about this stuff...that's scary
Amerikaner83 is offline
Old 08-07-2012, 10:22 PM
styliztik's Avatar
Az ftw
styliztik is offline
Old 08-08-2012, 10:36 AM
GGENIUS's Avatar
good thread. hopefully now we wont get a dozen threads a month with people asking if they should buy the cheap support.
GGENIUS is offline
Old 08-08-2012, 07:23 PM
Trini Boom's Avatar
We need to get a pic of the OEM support showing the extra piece of support. I think I have one somewhere...
Trini Boom is offline
Old 08-08-2012, 07:59 PM
^Send me a pic...I'll add it to the OP
Old 08-08-2012, 09:05 PM
T_Behr904's Avatar
This is a 5th gen problem as well.
And for those who are in dry states who think they are safe, don't be quite so sure. This problem starts from the inside-out, so if you see a bubble in the paint, jab at it with a large screwdriver to check it out. Once they start rusting, the rust spreads pretty fast.
Here's a couple pics of my old support after it was cut out.
T_Behr904 is offline
Old 08-08-2012, 09:41 PM
GGENIUS's Avatar
THE PROBLEM RELIES SOMEHWAT IN THE PREP WORK OF THE OEM SUPPORT. WHEN YOU REPLACE YOUR SUPPORT, MAKE SURE YOU USE MAD SEAM SEALER, AND UNDERCAOT THE **** OUT OF IT. AND THEN EVEN BASE COAT IT. AND BARE METAL SPOTS SHOULD BE PRIMED AND SANDED, THE WHOLE AREA SHOULD ALSO BE PRIMED AND SANDED AFTER ALL THE FOREMENTIONED THINGS ARE DONE. AND AFTER THAT, BODY FILLER SHOULD BE APPLIED ON THE GRINDED WELD ZONES TO MAKE THE MATING SURFACES LKE BRAND NEW. AND THEN YOU WANT TO SPRAY CAVETY WAX INSIDE EVERY SINGLE ACCESS WHOLE THERE IS ON THE SUPPORT. THE TYPE OF WELDING USED TO DO THIS IS SPOT WELDING. WHAT YOU WANT TO DO IS GET A HOLE PUNCH AND PUNCH A 1/4 HOLE IN THE NEW SUPPORT, IN THE SAME SPOTS THAT THE OLD SUPPORT HAD SPOTWELDS IN. YOU THEM LINE THE NEW SUPPORT UP WITH BOLTS, AND MAD CLAMPS TO ENSURE ITS LINES UP PERFECTLY BEFORE YOU MAKE ANY TACK WELDS. FIT IN PLACE ALL BOLTS IN ONLY HAND TIGHT. THEN TAK WELD INTO PLACE TO SUPPORT WHILE PLUG WELDING YOUR HOLES. IF YOU GO THE THESE EXTREMES, YOUR SUPPORT WITH NEVER RUST AGAIN.
GGENIUS is offline
Old 08-08-2012, 09:43 PM
GGENIUS's Avatar
AND WHEN I SAY SEAM SEALER, I MEAN SEAM SEAL EVERY ****IN PIECE THAT ISNT ONCE PIECE OF METAL.
GGENIUS is offline
Old 08-08-2012, 09:53 PM
styliztik's Avatar
here's mine fwiw
Old 08-09-2012, 12:01 AM
carsnwomen91's Avatar
nice post!
420th post ftw!
carsnwomen91 is offline
Old 08-09-2012, 12:06 AM
Originally Posted by styliztik
here's mine fwiw
snazzy protective coating on the frame there lol
Old 08-09-2012, 12:27 AM
styliztik's Avatar
I have no protective coating. That's 14 years, and 139,812 miles of Phoenix roads.
Old 08-09-2012, 01:54 AM
SandyMax96's Avatar
Good read! but I doubt us California folk have to worry about it, at least, not until maybe another 10-20 years.....
SandyMax96 is offline
Old 08-09-2012, 09:21 AM
Frank Fontaine's Avatar
Well at lease we don't have scorpions in the northeast....j/k that's amazing, what a difference. Ultimately though, very bad design on Nissan's part with these 4th and 5th gens....
Frank Fontaine is offline
Old 08-09-2012, 09:46 AM
GGENIUS's Avatar
wow, i had no idea the crossmember was supposed to be that black color. never seen one NOT rusted honestly!
GGENIUS is offline
Old 08-09-2012, 12:13 PM
styliztik's Avatar
In my 17 years of living here, I've never seen a scorpion. And mine just has oil soaked in it lol that's why it looks like that
Old 08-09-2012, 12:28 PM
Ad·min·is·tra·tor
DanNY's Avatar
smearing seam sealer is pretty much a waste of time.
use a good weld through primer.
yes you want to punch holes in the new metal and plug weld it.
a quality urethane undercoating would be good on the outside surfaces.
cavity wax is a good idea for the inside areas.
you need bare metal so the weld sticks...you can't weld over paint (aside from weld through primer)
big text and all caps = super annoying.
DanNY is offline
Old 08-09-2012, 02:05 PM
GGENIUS's Avatar
i realize that the big text and caps is "annoying," but i felt that some messages in there need to not be skipped over while reading this tread.
when i say bare metal spots, im talking about after your weld on the support, any left over bare metal should be primed.
when i did mine, i used seam sealer around the crossmember that bolts into the lower radiatior support, and around some places where rust appears most by seams.
but yes, i did forget weld through primer. definitely use that too. all of these combined will create a flawless rad support.
GGENIUS is offline
Old 08-09-2012, 03:48 PM
Trini Boom's Avatar
here's mine fwiw
Nice pic of the crossmember painted but those oil leaks gotta be eating away your bushings...
Old 08-09-2012, 09:34 PM
styliztik's Avatar
Really. -.- its not painted.
And not really. Just making a mess every where
Old 08-10-2012, 06:26 AM
Willing to learn
oldngivout's Avatar
That is an excellent write-up. Thanks for taking the time to document the problem. The pictures are really nice too.
oldngivout is offline
Old 08-10-2012, 07:04 AM
Snypa's Avatar
Good job. Very informative.
Snypa is offline
Old 08-10-2012, 07:50 AM
GGENIUS's Avatar
lol everyone thinks its painted cuz theyve never seen them not bright orange
GGENIUS is offline
Old 08-10-2012, 07:55 AM
Mine looks about like that, but not that black . Pretty close though.
Old 08-10-2012, 11:06 PM
styliztik's Avatar
also,, if anyone wants to help with my oil leaks don't be afraid to offer lol
Old 08-10-2012, 11:35 PM
schmellyfart's Avatar
Clean it up first, then I'll consider it.
schmellyfart is offline
Old 08-10-2012, 11:38 PM
styliztik's Avatar
I was actually gonna do that tomorrow. lol. it's starting to smoke a little =/
Old 08-11-2012, 07:26 AM
GGENIUS's Avatar
dude goes through the trouble of makin this thread and then he gets banned for no reason? blasphemy.
GGENIUS is offline
Old 08-11-2012, 08:32 AM
T_Behr904's Avatar
I don't see where anyone who has posted in this thread was banned...
Old 08-11-2012, 11:11 AM
styliztik's Avatar
I think he's talking about tsd? Idk
Old 08-11-2012, 07:34 PM
GGENIUS's Avatar
ill let him come in here and post if its not
GGENIUS is offline
Old 08-11-2012, 08:36 PM
Ad·min·is·tra·tor
DanNY's Avatar
i don't see anyone banned here.
and for the record people don't get banned "for no reason".
DanNY is offline
Old 08-11-2012, 08:59 PM
GGENIUS's Avatar
yessuh massuh
GGENIUS is offline
Old 09-22-2012, 03:59 PM
isrb710's Avatar
WOW!!!
Looking at these pics I had to crawl under my "lifetime in Ohio" 2000 Maxima. I couldn't see things real well due to the plastic cover. Through the cracks, I could see that it was all rust around where the support from the hood latch was supposed to be attached!
Are there any differences between fixing this on a 4th gen and a 5th gen?
Thanks, Ron
isrb710 is offline
Old 10-04-2012, 07:28 AM
aackshun's Avatar
Excellent thread bump.
aackshun is offline
Old 10-18-2012, 11:17 PM
chadroyal's Avatar
Nice thread yo
chadroyal is offline
Old 12-07-2016, 06:45 PM
maximatech12's Avatar
I got one rusted real bad and am lining it up to replace. These pictures are horrifying me! Which brand are these supports and did they come with a warranty? It looks like they broke from applying the lifting cup to the Nissan Jack point.
maximatech12 is offline
Old 12-11-2016, 07:54 AM
I don't think you HAVE to get a Nissan genuine support.
I think these pics above are from defective aftermarket supports.
The aftermarket supports look pretty solid!
I don't think they're too much different than what your getting from Nissan
Quick Reply: The definitive radiator core support thread
