Front bearing / hub problem
Old 07-16-2012, 09:41 AM
MaximaDriver
WielkiWaac's Avatar
Hello All.
I need to replace my front wheel bearing. Car was making noise when driving plus there is a play on wheel when car is on lift. Now, when I replace bearing should I replace hub as well? I dont have to much $$$ right now and dont want to buy new hub if old one is still in good condition (which I dont find out till everything is seperated).
WielkiWaac is offline
Old 07-16-2012, 09:58 AM
Quickywd01's Avatar
Czesc, you can re-use the hub but the bearing is pressed into it so either you have to do it or take it apart and take the hub and bearing assembly to a shop to press out the old bearing and press in the new bearing.
Quickywd01 is offline
Old 07-16-2012, 10:41 AM
MaximaDriver
WielkiWaac's Avatar
What brand would you recommend?
Old 07-16-2012, 11:57 AM
asand1's Avatar
I have seen wheel bearings on a Jetta so bad the hub was worn to the point of the bearing races being loose on the hub. You might order one locally in case you need it. If not, just dont go buy it.
asand1 is offline
Old 07-16-2012, 12:40 PM
VisciousMo's Avatar
I would replace the hub.
VisciousMo is offline
Old 07-16-2012, 12:52 PM
aackshun's Avatar
National Brand bearings = OEM supplier for many manufacturers, not sure for Nissan though.
aackshun is offline
Old 07-16-2012, 01:40 PM
mrjamaica98mx's Avatar
just had mine replaced mechanic said when he take it off it fell aprt in is hand i would replace the whole thing.
mrjamaica98mx is offline
Old 07-16-2012, 05:05 PM
nismomaxgtr18's Avatar
Just replace the hubs along with the wheel bearings. You can get OEM ones from nissanpartsasap.com.
nismomaxgtr18 is offline
HOKUSMAX
11-13-2017 04:34 AM
boomerbrian
11-08-2015 05:10 PM
homeyclaus
09-03-2015 06:15 PM
FanaticMadMax
08-10-2015 08:55 PM
Quick Reply: Front bearing / hub problem
