Troubled max
Old 07-14-2012, 05:48 AM
kellybwright's Avatar
Troubled max
98 maxima has trouble starting and when does it sputters an smells of raw gas?
Can anyone help??
Oh yeah engine light doesn't come on , even before start-up.
kellybwright is offline
Old 07-14-2012, 10:03 AM
The CEL bulb must be out. Get the code(s) and report back.
ChrisMan287 is offline
Old 07-14-2012, 03:50 PM
Trini Boom's Avatar
How long has it been blown?
Trini Boom is offline
Old 07-15-2012, 01:38 PM
All these codes showed uup
po100
po141
po446
po302
po325
p1105
p1400
p1490
p1492
where to start
Old 07-15-2012, 02:13 PM
tigersharkdude's Avatar
Go to post #3
http://forums.maxima.org/4th-generat...ere-first.html
tigersharkdude is offline
Old 07-15-2012, 03:15 PM
Trini Boom's Avatar
po100
po141
po446
po302
po325
p1105
p1400
p1490
p1492
where to start
Good grief man... Lets start with P0100 which is the MAF sensor and P0302 which is a misfire in cylinder 2. Inspect the ignition coil and check the spark plug. If the plugs haven't been replaced, replace all 6 and clean out MAF. The things these 4th gens go through I tell ya..
Old 07-15-2012, 04:03 PM
O.K I did check the coil and no spark so 1 problem solved, get back to ya on the MAF..Thanks 4 your help
Old 07-15-2012, 07:29 PM
mikeismike2's Avatar
Reset Codes?
Maybe you already did so, but did you reset the ECU and then see what you have left?
Hopefully you'll come up with just a hand full to troubleshoot instead of a basket full.
Just start the engine - go nowhere - and turn it off and see what codes show up.
mikeismike2 is offline
Old 07-16-2012, 11:17 AM
How do you reset ecu? dont have obd2 scanner is there any other way?
Old 07-16-2012, 11:33 AM
jholley's Avatar
Watch pmohr's video in post 9 of this thread that tigershark already provided
jholley is offline
Old 07-16-2012, 12:22 PM
Left-hand side of this page, about 7 items up - find VBX Maxima link for ECU reset info:
http://www.mikeskeys.com/auto.htm
Old 07-16-2012, 04:49 PM
WOW! Replaced coil pack on cylinder 2 and pow it runs great again! Best 100 bucks spent.
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
HOKUSMAX
11-13-2017 04:34 AM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: Troubled max
