No reverse or 1st gear is my tranny shot?
Went to back out of a parking spot but the car would not move, it felt like i had the brake on. So i tried D,2,1 Drive and 2nd worked 1st did not. i pushed the car out and limped her home.
I have checked the fluids twice now (hot and cold) and it looks like it overfull but i have not added any fluid. Also i noticed when it was hot i pulled the dipstick and it was smoking(very small amount). Fluid smells burnt.
Does my tranny have any chance? Writing this i feel i am answering my own question, i am just hoping i am missing something.
Any suggestions?
Any suggestions?
You and a 5th gen guy have the same issue lol Check it:
http://forums.maxima.org/5th-generat...a-shoot-b.html
I have reverse and 1st back! So, i was sitting in the car and i put it in reverse and i gave it a little gas and again it felt like i had my foot on the brake, well i got pissed and pushed the gas donw like 3/4 and all of a sudden BOOOOOM! before i know it im spinning the tires in reverse! ...everything's working again!
...Kinda short lived happiness i talked to SEVERAL shops and a friend that has been doing trannys for 30 years, they all said trannys dont "heal" themselves... i said but but but this is a maxima lol ... so i think im gonna do a rebuild on her
Cripes that was violent though. I held the brake as well just in case she decided to go forward.
Again. Kudos to you, and thank you very much. I am posting this so that others who may have the same issue can try this fix.
I drove it thins morning, and everything seems fine.
I will post updates if anything goes wrong.
scary, huh?
I figure a valve must have been stuck.
I change my fluid with Mobil1 ATF every 50k since I purchased the car at 100k. (260k is where am at now). The fluid smells fine, but Imma do a change soon.
after i did that the tranny seemed weaker i got flare-ups between shifts so i didnt wait for it to fail i swapped my tranny with a VLSD with only 69k on it, i couldnt be happier with VLSD ..that is except $1400 it cost me for tranny new solenoids axle two motor mounts fluid and labor.
Update
My tranny has gotten stuck like this two times since my last post.
The latest time I didn't thing I was gonna get it to pop out. I disconnected the drop resistor (so I would have full line pressure ALL the time) and after I got the tyranny fully warmed up, I did a neutral drop into reverse. It worked, but I am not gonna take it to a tranny shop. I'm sure its just a solenoid or something.
update,
tranny still works, but will occasionally do this sticking thing. It seemed to happen less as spring and summer came, so I assumed it would happen more frequently once it got cold.
Hence, I have retired my '98. She still runs and drives fine. I'm keeping it as a backup car.
Purchased a 2011 Max SV w/sport package. Finally Nissan has made a max worth owning again.
fx4five
10-18-2015 06:57 PM
fx4five
10-01-2015 04:58 AM
