Engine Help VQ30DE
Old 05-19-2012, 12:56 PM
Trini Boom's Avatar
Engine Help VQ30DE
Full story, my moms maxima had a bad fuel injector in cylinder 4. The engine hydrolocked from filling up with fuel. I got all the fuel out and went to crank and it was not turning over. I manually cranked it very slowly for a few minutes for it to become free. After that, the engine fired up. Now there is a new problem. When the car reaches operating temperature, white smokes comes out of exhaust.
There is no coolant/oil contamination from engine oil or radiator. The smoke smells like oil. I am leaning towards the rear main seal because from cold, the car starts fine and does not smoke. When temperature gauge reaches half way is when the smoking starts. Any suggestions?
Trini Boom is offline
Old 05-19-2012, 01:32 PM
maxfever1987's Avatar
Usually that points to antifreeze, is this the same car u replaced the fuel rail on?
maxfever1987 is offline
Old 05-19-2012, 02:56 PM
cDgRazoray's Avatar
I had the same issue this weekend. White smoke with no oil/coolant mix in the oil pan or radiator. Engine passed compression test on all cylinders. Added a couple quarts, let the car run for a few minutes and noticed my rear main seal was leaking pretty bad. Now I'm looking for a mechanic that doesn't want to rape my wallet...
cDgRazoray is offline
Old 05-19-2012, 09:01 PM
Trini Boom's Avatar
Same car. Just took it on the highway and drove it out. Don't see any smoke now but will verify in the morning.
Old 05-20-2012, 07:11 AM
Trini Boom's Avatar
Just went to let the car warm up. Revved it some and saw no smoke. It must have been unburnt fuel that was sittin gin the exhaust. Its fine now...
shilov
02-19-2024 09:40 PM
James92SE
142
01-02-2024 09:23 AM
msellas
09-23-2015 09:16 PM
Socalstillen
09-20-2015 11:46 PM
seesole
09-14-2015 12:38 PM
Quick Reply: Engine Help VQ30DE
