Can I install any other oem stereo in my 4th gen?
Hi guys im knew to car audio and I was wondering if I can install a newer oem nissan,infinity stereo with little to no modifications to the harnnes...
I have the original 98 double dine none bose Head Unit.
Thanks in advance.
Thanks in advance.
I think an 04-07 Pathfinder BOSE Headunit will work with lil or no modification.
http://forums.maxima.org/4th-generat...disc-bose.html
EDIT: Requires BoSE / and splicing one wire it looks like..
good luck
good luck
ive wondered this myself. i want a double din touch screen display with cd/mp3/gps. not sure which cars have them but honestly it shouldnt be too hard to make your own harness. 12 or so wires: power,switch,illumination,ground,pos.&neg. for 4 speakers,remote and auxiliary if you have an amp and subs. someone correct me if im wrong but you find a diagram for both harness for your car and harness for the player you should be able to snip the plugs and match the wires by function not color. mounting is a different story but brackets shoudnt be hard to make either. hope this helps.
+1 on aftermarket
You could get any other 4th gen non-bose and plug in, so long as the connectors match (or rig an adaptor), or you can go to crutchfield and get one. Comes with adapter, mounting hardware, and antenna adapter, mostly plug and play!
You can get one that has bluetooth and sync that with the receiver and use pandora on there. As long at there is an addon on there or it already has it. The pioneer would be a better one to go with seeing that it has more options and has hd radio and bluetooth.
Finkle
09-27-2015 09:53 PM
MikesChevelle
08-06-2015 11:36 AM
ViciousVQ30
08-05-2015 05:40 PM
