Weird ANNOYING Awful noise
Old 04-12-2012, 08:40 AM
demon_maxima's Avatar
Ok, Here we go. I have an Awful noise that sounds like it is coming from the A/C compressor. When the car is on(At IDLE), there is a nya nya nya nya nya noise that sounds like a diesel would. I have no idea what would cause this noise, but it is getting worse and is driving me crazy. With an Intake and Exhaust, i can STILL hear this noise over my engine.
Thanks !
demon_maxima is offline
Old 04-12-2012, 09:19 AM
asand1's Avatar
Is the noise present with AC on? Off?
Remove the AC/Alt belt. Run to confirm the noise is gone. Spin the AC clutch by hand to check the clutch bearing. Spin the Alt to check it as well.
asand1 is offline
Old 04-13-2012, 08:42 AM
the noise gets so much louder and noticeable with the A/C Off
Old 04-13-2012, 08:44 AM
I will pull the belts today, but im starting to think its the TC tensioner... Which i HOPE it is not.
Old 04-13-2012, 10:17 PM
Quickywd01's Avatar
Thanks !
A/C compressor bearing is failing.
Quickywd01 is offline
Old 04-16-2012, 06:16 AM
You hit it on the nail. i pulled the belt friday and spun the pulley...shakes a bit and you can hear it rattle. Thank GOD its not the timing chain tensioner!
Old 04-16-2012, 06:22 AM
cashoit's Avatar
what do u mean thank god???
Freakin new compressor costs more than replacing the engine lol
cashoit is offline
Old 04-16-2012, 06:27 AM
Doughboy89's Avatar
Damn, I just sent my parts car off with a good compressor. Didn't want to let the refrigerate out in my garage.
Doughboy89 is offline
Old 04-16-2012, 10:02 PM
Trini Boom's Avatar
Just swap over the bearing and clutch assembly. You will not need to release the freon to do this.
Trini Boom is offline
Old 04-17-2012, 08:23 PM
Whatchyou say?
JtzMax's Avatar
You can use a steering wheel puller to remove the pulley assmbly from the unit. You will need to watch out as there's not a lot of room but a trick around this is to pull the 4 mounting bolts, drop the unit down then replace the top two bolts in the bottom holes. Gives you more room to work. I suggest an FSM if you don't have one. Will give you the exploded view of the AC compressor ... there's a small "C" clip in back of the pulley, holds the bearing on. Not a bad job really ... doing an engine is worse IMHO!
Cashoit !!!! Sup Bro!
JtzMax is offline
Old 04-18-2012, 09:06 AM
I say thank god because its not engine- Threatening, Since i am still in highschool and live with my mom and she still thinks that anything that goes wrong with the car is my fault(Wont let me pull engine), and there is a write up on how to do it right here:
http://www.vqpower.com/v2/articles.php?article_id=112
Old 04-18-2012, 09:07 AM
Damn straight.
hcarter1112
42
07-18-2022 03:35 PM
tarun900
19
12-20-2021 06:57 PM
D Mason
06-21-2016 04:43 AM
mpbclutch33
12-26-2015 11:11 AM
uttadms31
09-30-2015 05:24 AM
Quick Reply: Weird ANNOYING Awful noise
