egr CODE 0302
egr CODE 0302
THOUROUGHLY cleaned egr vlave, throttle body, replaced knock sensor and cleaned ivac still getting the code... i really dont want to do that whole job over.. anyidea...been two weeks with no inspection because of thiis code
repost...My P0400, 0302 cel was solved by replacing the EGR solemoid valve ( green Connector ). I replaced it, but took apart and cleaned the old one and now that one is working fine too. Easy to clean, only one moving part inside, a spring and 2 O rings. Hard part is taking it out and putting it back in. So save some money and try cleaning it first...david
I type really slow...so here are some links...you can test it first to see if it clicks before removing it. Also if you have a "99 the this is not your problem. GL
http://forums.maxima.org/4th-generat...oid-valve.html
http://forums.maxima.org/4th-generat...d-contorl.html
http://forums.maxima.org/4th-generat...lve-issue.html
See my solution in this thread http://forums.maxima.org/8425603-post13.html
Kyle Lee Cleveland
09-28-2015 09:01 PM
