Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 04-03-2012, 01:58 PM   #1
Points: 6,367, Level: 52
Points: 6,367, Level: 52 Points: 6,367, Level: 52 Points: 6,367, Level: 52
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
https://www.facebook.com/steve.booth.9 MaximaGTR
Poor idle after changing valve cover gaskets.
As title says, i changed both valve cover gaskets and its idling horribly....when cold it idles ok around 1200-1000 but feels like it misses or stutters....when warmed up its way worse, hunting between 750 and 300 rpms, shakking badly etc...i double checked everything for intake leaks etc...even sprayed some either around UIM gasket to check for leaks....im wondering if its IACV finally crapped on me.
I should add that when driven the car drives beautifully and leaks not a drop of oil anymore...., however when i clutch it to come to a stop it idles almost to 0 before catching itself and even dies sometimes if i dont tap the gas....
plz help, thank you!!
EDIT* new UIM-LIM gasket installed when it was off too...
__________________
1992 Maxima SE Auto *Sold
1996 Maxima SE Auto *Sold
1995 Maxima GLE Auto *Sold
1997 Maxima SE 5spd *Sold
1995 Maxima SE 5spd Sumer DD
1995 Subaru Outback 2.2 AWD Winter DD
1992 Mitsubishi Galant VR4 #65/1000 Fun Car!
Boothers96 is offline   Reply With Quote
Old 04-03-2012, 02:03 PM   #2
GOT RETROFIT?
Points: 16,956, Level: 83
Points: 16,956, Level: 83 Points: 16,956, Level: 83 Points: 16,956, Level: 83
Activity: 25.0%
Activity: 25.0% Activity: 25.0% Activity: 25.0%
Vacuum leak.
__________________
http://www.retrofits-r-us.com/
http://www.youtube.com/chrisman287
Quote:
In Carbon Fiber we trust. Amen.
ChrisMan287 is offline   Reply With Quote
Old 04-03-2012, 02:29 PM   #3
Points: 18,287, Level: 85
Points: 18,287, Level: 85 Points: 18,287, Level: 85 Points: 18,287, Level: 85
Activity: 12.2%
Activity: 12.2% Activity: 12.2% Activity: 12.2%
aackshun
Send a message via AIM to aackshun
Raise idle, spray wd-40 all over the UIM gaskets, if it dies when you spray it, you sir have located your vacuum leak.
__________________
Recipient of the Weirdest Ghustler Award (2012)
Daily: 03 I35 6MT + AltiMax Motor AKA your favorite Sleeper's sleeper
Project/Road Course Car: 99 AR2 SE-L 6MT + ????? on ?????
http://aackshunsgarage.blogspot.com
- For up to date 's and motoring.
aackshun is offline   Reply With Quote
Old 04-03-2012, 03:05 PM   #4
Points: 6,049, Level: 50
Points: 6,049, Level: 50 Points: 6,049, Level: 50 Points: 6,049, Level: 50
Activity: 2.6%
Activity: 2.6% Activity: 2.6% Activity: 2.6%
Quote:
He did not raise idle, but did spray wd-40 over the UIM gasket(in his post)
Im guessing IACV if it is only the idle that is ****ty, but when you give it gas is ok. All your vacuum hoses connected good? Take your IACV off clean it, and test that all connectors on IACV are functioning. Changed both of my valve cover gaskets, spark pluk gaskets(one was leaking oil) a couple years ago, but did not have issues like you so
__________________
vilmaxima is offline   Reply With Quote
Old 04-03-2012, 03:49 PM   #5
Activity: 0%
Thats what i was thinkin.....ill recheck all hoses tonight i did replace a few hoses (breateher hose between both vc, coolant hose on rear of uim n a few brittle vac hoses right under the tb) i also cleaned maf, tb, egr tube and iacv as per the thread on that subject and replaced all gaskets w oem nissan.
Old 04-03-2012, 03:50 PM   #6
Points: 5,283, Level: 46
Points: 5,283, Level: 46 Points: 5,283, Level: 46 Points: 5,283, Level: 46
Activity: 1.1%
Activity: 1.1% Activity: 1.1% Activity: 1.1%
hope its your IACV and not a harness issue. Moving an old harness around to remove the UIM can break wire on the quickness.
__________________
(4) 800 miles old Yokohama YK580 205 65R15 tires PM for info and pics
2 89+ 300zx Akebono rotors/ Already milled for use with BBK without bracket
ShocknAwe is offline   Reply With Quote
Old 04-03-2012, 04:03 PM   #7
Activity: 0%
Quote:
My VERY first thought and worry.....but i would think if it was a harness issue it wouldnt only b on idle....it would affect the car w load on and off the engine and at all rpms.....also btw no codes
Old 04-03-2012, 04:12 PM   #8
Activity: 1.1%
Not if its the IACV because it only takes over at idle, part of the ECU that controls the IACV can fry as well.When I had a screwy idle I first checked for leaks and such and found none. THen I got an IACV code and was relieved becuase I thought I would go to the pull-a-part, swap it out and be done. Didnt fix it. Come to find out the ECU can fry and you need to repair or for most people, replace it. Test the IACV. Should be 30ohms resistance. Then trace the wiring. First check for leaks though, hoses can have a crack
__________________
Old 04-03-2012, 04:13 PM   #9
Activity: 2.6%
Quote:
Exactly as u stated, unless the wires only affect idle. Maybe a wire that is hitting ground sometime(small split), give it a good visual check. Everywhere. Also when did you clean or replace your air filter, fuel filter, or spark plugs? What I forgot, how is your main ground wire? Or do u have a grounding kit?
__________________
Old 04-03-2012, 04:46 PM   #10
Activity: 0%
Replaced fuel filter w z32 about 2000mi ago, spark plugs r ngk platinums replaced same time, and air filter is k&n cone snd was cleaned/oiled last fall......coils are all used off low mileage junk car been on their less than a month....i ohm tested rear injectors since i had uim off....all tested 12.1-12.6
Old 04-03-2012, 04:49 PM   #11
Activity: 0%
Oh and i have a ground kit.....one from bat-body, one uim-firewall, one tb-body, one timing cover-body. All are 2 ga w gold terminals
Old 04-03-2012, 05:08 PM   #12
Points: 35,333, Level: 100
Points: 35,333, Level: 100 Points: 35,333, Level: 100 Points: 35,333, Level: 100
Activity: 11.4%
Activity: 11.4% Activity: 11.4% Activity: 11.4%
Send a message via AIM to njmaxseltd
, part of the ECU that controls the IACV can fry as well.u
This issue only applies to 5th gens.
__________________
As the 4th gen ages, its owners get younger.
njmaxseltd is offline   Reply With Quote
Old 04-03-2012, 05:36 PM   #13
Activity: 1.1%
Quote:
your 100% sure of that? Because if so then I need to reevaluate my solution. I havent checked my harness though, that and the ECU are all I have left
__________________
Old 04-03-2012, 05:59 PM   #14
GOT RETROFIT?
Activity: 25.0%
He's 100% right.
__________________
Old 04-04-2012, 04:40 AM   #15
Activity: 11.4%
IACV will not cause a rough idle (misfire). It only controls idle speed.
If the valve fails to function and is closed the idle speed will default to the throttle body setting, which should be about 550. If it fails open you'll have a very high idle.
The valve only controls air flow which in turn sets idle speed.
Old 04-04-2012, 04:58 AM   #16
Points: 8,298, Level: 61
Points: 8,298, Level: 61 Points: 8,298, Level: 61 Points: 8,298, Level: 61
Activity: 4.8%
Activity: 4.8% Activity: 4.8% Activity: 4.8%
a simple resistance test for the IACV will tell u if its good or not. Test IACV per how tos
cashoit is offline   Reply With Quote
Old 04-04-2012, 12:45 PM   #17
Points: 7,831, Level: 59
Points: 7,831, Level: 59 Points: 7,831, Level: 59 Points: 7,831, Level: 59
Activity: 4.1%
Activity: 4.1% Activity: 4.1% Activity: 4.1%
Make sure your coilpack connectors are snapped all the way on. It's a long shot, since that would likely affect driveability too, but it's easy enough to check.
__________________
**If I can't fix it, it deserves to stay broke.**
DBear is offline   Reply With Quote
Old 04-04-2012, 02:15 PM   #18
Points: 9,486, Level: 65
Points: 9,486, Level: 65 Points: 9,486, Level: 65 Points: 9,486, Level: 65
Activity: 1.1%
Check your throttle cable to make sure its not to loose.
NABU6 is offline   Reply With Quote
Old 04-04-2012, 02:16 PM   #19
Points: 2,151, Level: 28
Points: 2,151, Level: 28 Points: 2,151, Level: 28 Points: 2,151, Level: 28
Activity: 3.3%
Activity: 3.3% Activity: 3.3% Activity: 3.3%
Send a message via AIM to Timm80
Check all your hoses, they get brittle and crack really easily. I replaced my valve cover gaskets a few months ago and had to get 3 new hoses because they broke or cracked badly. There are a lot of little hoses connected to the UIM and throttle body. When you took both off did you number each hose and connecter and what it attaches too? Thats what I did and putting everything back together was a breeze. If you didn't, visit one of your friends who has a same year maxima as yours and compare everything in your car to his to make sure you put everything back together properly. My guess is you forgot to plug a hose back in or plugged one of the hoses into the wrong spot, seeing as how this started after you put everything back together.
Timm80 is offline   Reply With Quote
Old 04-04-2012, 03:46 PM   #20
Activity: 0%
Quote:
I didnt label....smh...and i also dont have friends around w maximas.....i thought of "test driving" the only one on cl in tyler n check it out.....i could also go to a pick n pull n check out vac routing.....or if someone w a 95 would b awesome n post a pic just under the tb where all the little hoses connect id b much obliged.....ps its not coils, iacv, or maf, and i dont find any vac leaks.....REALLY hoping its not electrical at this point!!
Old 04-04-2012, 06:13 PM   #21
Points: 3,819, Level: 39
Points: 3,819, Level: 39 Points: 3,819, Level: 39 Points: 3,819, Level: 39
Activity: 0%
Send a message via Yahoo to BrooklynCyclone
Definitely a vac,loose or in a wrong location since when driven all is well.....
BrooklynCyclone is offline   Reply With Quote
Old 04-04-2012, 08:04 PM   #22
Points: 5,765, Level: 49
Points: 5,765, Level: 49 Points: 5,765, Level: 49 Points: 5,765, Level: 49
Activity: 0%
Quote:
Originally Posted by ChrisMan287 View Post
Vacuum leak.
What he wrote.
There is ample potential for creating a vacuum leak doing this job.
Recheck all the vacuum hoses and breather hoses.
iDuty is offline   Reply With Quote
Old 04-06-2012, 04:47 PM   #23
Activity: 0%
ok so i went over this again today checking and replacing more hoses as i went....and i found the issue. It was the egr valve gasket, for some reason it had slipped off the far bolt and was hanging by the front bolt (bolt you can see)....so i got it on there right, put it all back together and what do you kno.....car runs like it should.
I appreciate all the help you all give we with this car...i am limited on knowledge but willing to try and learn whatever! thanks again!!
__________________
Old 04-07-2012, 12:12 AM   #24
Points: 9,450, Level: 65
Points: 9,450, Level: 65 Points: 9,450, Level: 65 Points: 9,450, Level: 65
Activity: 3.3%
glad you found the problem . I was going to post basically that. when I did my valve covers years ago . I left the EGR tube bolts loose and had exactly that problem . tightened them up and idled perfect after that
__________________
Audio,Mobile Es Head Unit,2 RFP1812 12's ,RF Punch 400.4 ,Crossfire 402,DEI 6.5 components 2 sets,
flynlr is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
