Warning: When changing front suspension!
Old 04-01-2012, 09:25 AM
nab911's Avatar
Finally got around to putting in my new shocks and springs and after we got everything all wrapped up, started the car and put it in reverse and something was wrong. Heard a weird noise and when I put it back in park there was a metal "crunching" noise.
Come to find out, when we pulled off the driver's side shock, the steering knuckle hung down so low it pulled the cv axel out. Tore the boot and everything. Had to get a new boot, pull the axel out from the knuckle and get it set back straight so we could reinsert the shaft. AFTER all that everything was fine but added about another 5 hours on the job.
SO, to conclude, support the rotor assembly when changing shocks!!
nab911 is offline
Old 04-01-2012, 09:31 AM
ShocknAwe's Avatar
lol yea a bunjee cord is your friend
ShocknAwe is offline
Old 04-01-2012, 09:44 AM
beegeezy's Avatar
Yep, bungee cord hooked to the strut tower FTW.
beegeezy is offline
MAXIMA_STYLE's Avatar
hahaha ive seen people do this so many times....rookie mistake... safety wire is your friend
MAXIMA_STYLE is offline
Old 04-01-2012, 10:13 AM
nab911's Avatar
I read through quite a few guides and it was never mentioned so just throwing it up there for everyone else as a warning . Luckily just some time and a $20 cv boot.
nab911 is offline
Old 04-01-2012, 01:47 PM
Stoneyburt's Avatar
Wow... I thought I was the only one this happened too. It wasn't funny at all when it happened as it added an extra amount of time to the install. Ohh well lesson learned.
Stoneyburt is offline
Old 04-01-2012, 04:56 PM
NABU6's Avatar
Another solution is to use a jack to support the control arm while removing the shock.
NABU6 is offline
Old 04-02-2012, 06:26 AM
cashoit's Avatar
does the haynes or FSM mention supporting the hub when doing struts install??
cashoit is offline
Old 04-02-2012, 06:39 AM
jholley's Avatar
I raised the LCAs when replacing front struts 2 years ago.
jholley is offline
Old 04-02-2012, 10:51 AM
WendysMaxima's Avatar
Happened to me, didn't tear the boot or nothin' but the axle popped out, mine was on passenger side though. sure was a pain. I had to do mine alone too. Good thing I can push the control arm down with one leg, and arrange the steering knuckle and the bolts that hold it in at the same time!
WendysMaxima is offline
Old 04-02-2012, 11:14 AM
Dsquared97maxse's Avatar
i got lucky doing mine, i caught it just in time. i like the jack idea i didnt think of that i just used string lol
Dsquared97maxse is offline
Old 04-03-2012, 12:13 PM
kel456's Avatar
will need to do this soon. my question is how did you screw tighten anything back if it did not aligned?
kel456 is offline
Old 04-03-2012, 03:15 PM
vilmaxima's Avatar
Lol, same happened to me first time on passenger side, boot did not rip, was able to somehow get the cv joint back together by myself with the boot still on. It took some time tho.
vilmaxima is offline
Old 04-03-2012, 03:39 PM
I bet it was a whole lot of bad words and jamming the damn thing in. Then you get that sense of victory when all the teeth line up and they go in. Quality.
Old 04-03-2012, 03:43 PM
99SE-L5SPEED's Avatar
me to help my cuz and his came out driver side
99SE-L5SPEED is offline
Old 04-03-2012, 03:46 PM
vilmaxima's Avatar
Exactly, then celebrate with a few beers(after!!! not while working, since it will slow down the process and might cause slight confusion, LOL)
Old 04-03-2012, 05:31 PM
xtremepb0's Avatar
THIS.... plus if your doing coilovers and going lower you need to push the whole thing up to get the steering knuckle to line up with the new suspension.
xtremepb0 is offline
Old 04-03-2012, 06:06 PM
GGENIUS's Avatar
i dunno about you, but i always include alcohol with my off the clock vehicle projects.
GGENIUS is offline
Matt93SE
05-24-2019 02:58 PM
HOKUSMAX
11-13-2017 04:34 AM
laparka66
08-06-2015 09:36 AM
RealityCheck
08-05-2015 06:18 AM
Quick Reply: Warning: When changing front suspension!
