ANYONE KNOW O-RING SIZE OF CAMSHAFT PS?
Old 03-17-2012, 01:03 PM
surban1's Avatar
i'm going to be removing, inspecting and cleaning the camshaft position and both crankshaft position sensors now that it's getting warm out once again. i don't see the camshaft ps o-rings' size listed in the 96 fsm or haynes manual. does anyone here know what size o-ring it needs? thanks.
surban1 is offline
Old 03-17-2012, 01:38 PM
BenL's Avatar
I honestly went to autozone, pulled the cps and took it in with me (isn't difficult to remove/install anyway). They cut the old one off for me and fitted a new one to it and I was good to go after paying the few bucks for the pack of o-rings (I now have several of them for the sensor laying around here somewhere), and of course I had some vaseline in the car to make sure the o-ring wouldn't get damaged during installation since it was a tight fit.
BenL is offline
Old 03-17-2012, 02:46 PM
atriuum's Avatar
I bought a set from Pepboys for $7. The package has like 12 o-rings of different sizes, and you just take the old one and match it to one of the o-rings in the set. You don't need to know the size because they are not sold by size.
It's in an isle with all the crap in it. LOL
Also, a good idea is to clean the oil off the sensor. I am pretty sure you DON'T want oil to contact the new o-ring until after it is installed. I think it seals better if it's installed dry, not oiled, to clean metal.
At east I remember my new oring failed quickly, when I didn't clean the oil off the surfaces.
atriuum is offline
Old 03-19-2012, 07:15 AM
Phromethius's Avatar
it was a number 15 o ring, not sure what size but yeah I just removed it in the parking lot and took it in to match. Cost me 69 cents to replace and no more oil leak out of that hole!
Phromethius is offline
Old 06-12-2012, 06:45 PM
surban1's Avatar
fyi: i measured the o-ring i just took off the cam sensor and its just over 18mm id X just over 22mm od X just over 2mm thick widthwise & just under 3mm thick heightwise. it was not leaking and a bit flattened in width. from this, i think that maybe 17mmX22mmX2.5mm (or maybe even 18mmX23MMX2.5mm) may be a better choice.
surban1 is offline
Miket2006
03-01-2021 03:55 AM
knight_yyz
11-01-2015 01:34 PM
msellas
09-23-2015 09:16 PM
Quick Reply: ANYONE KNOW O-RING SIZE OF CAMSHAFT PS?
