If you know how to do your own work, DO IT!
Old 03-09-2012, 11:57 AM
TreizeRXH's Avatar
I got lazy, was going to do the radiator, at the moment of truth caved in and let the shop do it because I went in to ask them to drill out broken bolts from the radiator support brackets. I'm feeling jackass's remorse now for letting myself get robbed $100 extra bucks that could have been saved by doing it myself.
SAVE YOURSELVES......the MONEY!! No one will care more about your car than you!
TreizeRXH is offline
Old 03-09-2012, 12:06 PM
anomaly117's Avatar
sad story. wrong forum.
anomaly117 is offline
Old 03-09-2012, 12:08 PM
tigersharkdude's Avatar
not sure of this thread..
tigersharkdude is offline
Old 03-09-2012, 12:11 PM
odawg23's Avatar
wrong forum but anyways..this is true..u were better off grinding the bolts out yourself...my friend took his car to a shop to change his brake pads and his transmission that was slipping and he ended up paying $2000...totally robbed...and at the end of the day the transmission that they supposedly fixed gave out and he had to spend 2200 on a new one...so do the work yourself or if you are gonna take it to a shop it better be someone you know cuz otherwise 9 times outta 10 they will screw you over
odawg23 is offline
Old 03-09-2012, 12:50 PM
anomaly117's Avatar
beat ya to it
Old 03-09-2012, 01:58 PM
styliztik's Avatar
yeah. I took my car to get the pass axle replaced and they fked it up. now I leak transmission fluid.
styliztik is offline
Old 03-10-2012, 12:35 PM
steezmuffin686's Avatar
did they replace the axle seal?
steezmuffin686 is offline
Old 03-10-2012, 04:36 PM
GGENIUS's Avatar
lets all post obvious *** threads.
GGENIUS is offline
Old 03-10-2012, 04:38 PM
odawg23's Avatar
lmfao
odawg23 is offline
Old 03-11-2012, 04:43 AM
edwardh1's Avatar
you might ask around and find an honest repair shop, start asking people they do exist, many are small but big enuf to have diagnostic equipment, find one where the owner works in it every day
edwardh1 is offline
Old 03-11-2012, 05:24 AM
mrjasonlyrics's Avatar
I hear that. I got a $140 quote to change my rad. I went home,jack up my car,drain out the rad fluid,change the rad,bleed the system but air pockets in less than an hour with no clue of experience how to do it. Felt damn good to save myself from paying to do something so easy. If you think you can do it then do it,just have a plan B...
mrjasonlyrics is offline
Old 03-11-2012, 03:51 PM
sjonesist's Avatar
I must admit that I was lazy for a while until I had some ac work done and they poked a hole in my leather seat. Now the car(s) have not been to the shop in years. Some things will really test you though like my current exhaust problem.
sjonesist is offline
Old 03-17-2012, 02:54 AM
eddie982's Avatar
Thankfully i've found an honest, cheap mechanic.
Had front rotors and front and rear pads replaced, rear left caliper and front right
caliper replaced, driver side axle replaced, new plugs put in- $240 labor
eddie982 is offline
Old 03-17-2012, 06:52 AM
Rods03Max619's Avatar
Id you got the time and the tools, do it yourself I'm all about saving money, was going to get my mechanic to install my headers for 250, but did it myself, usually you don't need that many tools anyway.....Good Luck Next Time Around.....
Rods03Max619 is offline
mvm062
11-30-2020 09:00 AM
kmitchel
10-30-2015 10:12 AM
Maxima30
09-07-2015 06:13 PM
iflexsteel
09-02-2015 08:04 AM
Hailstatejig
09-02-2015 06:52 AM
Quick Reply: If you know how to do your own work, DO IT!
