Lower Radiator Support pics and helpful hints
Old 12-30-2011, 05:16 PM
valveguy's Avatar
My son and I just changed the water pump, chain tensioner, idler pulley and lower radiator support on his 96 SE 5-speed. There are a couple of posts on radiator support that were very helpful. A couple of things that we learned that others might find helpful are as follows:
· The spot weld cutter we preferred was the type which drilled a “plug” as shown on the top in the picture below. We used the type that drill a hole, as shown in the bottom picture, but the plug type performed better for us.
· Locate the spot weld, and mark it good with a center punch. Then use a 1/8 drill and drill a good starter hole. Then use the spotweld cutter to drill through the first layer of metal to release the weld. The extra steps with the punch and drill, keeps the cutter from wandering. Here are both sides of the support and welds we removed.
· We bought an OEM radiator support on-line from a dealer in Arizona for $140. Horror stories in the org of failed aftermarket supports had us worried, so we popped for the extra 75 bucks or so.
· Prior to installation, we sprayed the outrside and inside with an internal frame protective coating from Eastwood. It comes with a special nozzle and hose that worked well.
· We waited until the new one came in before we completely removed the old one to make sure we didn’t do any more de-construction than we really needed to do.
Here a couple of pics, as you can see it was really bad. We have more if anyone is interested. We ended up with these two plastic covers leftover, from all the work (idler pulley, water pump, and radiator support replacement). If anyone can tell us where they go, please let us know. Thanks.
The Forgotten (Unknown) plugs.
valveguy is offline
Old 12-30-2011, 07:11 PM
4th Gen Parts King
Maxima_Joe's Avatar
Forgotten unknown plugs are from the wiper arms.
Maxima_Joe is offline
Old 12-30-2011, 08:19 PM
valveguy's Avatar
Thanks. We took the wiper arms off to paint them---and they are still off the car!!
valveguy is offline
Old 03-10-2013, 05:55 AM
tpwu's Avatar
Did anybody use rivets instead of welding?
tpwu is offline
Old 03-10-2013, 07:35 AM
tigersharkdude's Avatar
^weld or bust
tigersharkdude is offline
Old 03-11-2013, 10:47 PM
Nite Rider's Avatar
Nice pics. Your rad support was bad. Now I'm gonna have to check mine.
Nite Rider is offline
Old 03-12-2013, 05:45 PM
Snypa's Avatar
I too just had mine changed 3 weeks ago and I def recommend the OEM part for sure !
Snypa is offline
Old 03-27-2013, 06:57 PM
tpwu's Avatar
Hey guys, how did you guys remove the weld spot on the side near a/c condenser? There's not enough space to drill it out in that corner.
tpwu is offline
CRizz
41
06-07-2021 05:42 AM
maxinout93
10-27-2015 01:29 PM
acw
08-13-2015 12:50 AM
Quick Reply: Lower Radiator Support pics and helpful hints
