Ball Joint Bad?
Ball Joint Bad?
Went and had 2 front tires installed. The guy tells me I have a bad drivers side ball joint. went home jacked up the car and and there is no loose movement when I move the tire up and down or back and forth. Think they were trying to sell me something I didn't need? Is there another way to check? Car seems to drive good although It feels like it pulls to the right.
the ball joint would be leaking and the free play would be felt in the camber. you should be able to hear a knock and the vibration will be worst when you turn the car in the opposite direction of the bad ball joint.
Hit a bump and see if there a rapid vertical vibration or place a prybar, 2x4 under the front wheels while jacked up, work the wheel up and down 12 o' clock to 6 o'clock and feel the balljoint for play..... tierods are a lateral movement if you shake the wheel from 3 to 9 o'clock....and feel your outer and inner tierods for play!
litch
123
01-04-2024 07:01 PM
RealityCheck
10-02-2015 06:34 PM
