Video Of My Problem Noise
ok a guy at work tells me its my tensioner pully another guy says its my alt. i dont have a clue besides the fact its anoying as hell and really loud .......
video
http://youtu.be/3-jbTVyS9uo
check it out let me know what you think
video
You need to do the screwdriver to the ear test to figure out which device is failing. You can also take the belt off and spin each one by hand to figure out which one is failing.
We can only offer you a guess.
im hoping for a fix i can do my self lol im gonna look into it this weekend im guessing ill just have to pull the belt and spin the pully's one should be loose or something not rite
wouldnt be the ac compressor rite ? wouldnt hear that unless it was on ?
It could be your tensioner, alternator, crank pulley (we don't technically have a harmonic balancer) or your belt is loose.
Start by checking your belt. See if its on there kinda tight. Then do the screwdriver test or remove the belt and check them by hand like the other member stated.
It's much easier to use in the engine compartment, and you get to wear a white coat while you're doing it...
mikeg75
11-30-2015 05:12 PM
ballerchris510
09-11-2015 05:29 PM
