1998 maxima 04 3.5 swap starting problem
I have a 98 maxima se, with a 04 3.5 in it....when the guys doing the swap completed the swap they said it ran for 45min then they cut it off and now it will not start....
Specs..
.04 VQ35de
.SSIM manifold
.01 pathfinder throttle body
.3.0 ECU
.3.0 Harness
.Injen CAI
.3.0 headers
.DEK Injecters
.DEK Fuel Rail
.NGK spark plugs
.Machine shop cam adapters
.3.0 oil pan
.new starter
.new battery
.adjustable fuel pressure regulator
....really need help with this car really getting on my nerves.... Car just cranks and cranks and cranks....i can smell the gas.. And im getting spark......PLEASE HELP....ANY SUGGESTIONS
Specs..
.04 VQ35de
.SSIM manifold
.3.0 ECU
.3.0 Harness
.Injen CAI
.3.0 headers
.DEK Injecters
.DEK Fuel Rail
.NGK spark plugs
.3.0 oil pan
.new starter
.new battery
Specs..
.04 VQ35de
.SSIM manifold
.3.0 ECU
.3.0 Harness
.Injen CAI
.3.0 headers
.DEK Injecters
.DEK Fuel Rail
.NGK spark plugs
.3.0 oil pan
.new starter
.new battery
Specs..
.04 VQ35de
.SSIM manifold
.3.0 ECU
.3.0 Harness
.Injen CAI
.3.0 headers
.DEK Injecters
.DEK Fuel Rail
.NGK spark plugs
.3.0 oil pan
.new starter
.new battery
I sure hope so the people that was doing my swap had it running, they showed me a video and i can see that it was my car that was running, and they said they just pushed it up to around 60mph so idk.....its like i cant stop because im already money wise deep into the swap but yet this issue is killing my hopes of it running.
Specs..
.04 VQ35de
.SSIM manifold
.3.0 ECU
.3.0 Harness
.Injen CAI
.3.0 headers
.DEK Injecters
.DEK Fuel Rail
.NGK spark plugs
.3.0 oil pan
.new starter
.new battery
Specs..
.04 VQ35de
.SSIM manifold
.3.0 ECU
.3.0 Harness
.Injen CAI
.3.0 headers
.DEK Injecters
.DEK Fuel Rail
.NGK spark plugs
.3.0 oil pan
.new starter
.new battery
when i pulled the motor the valves were bent in the rear bank timing jumped, hope its not the case for you. spray starter fluid in the throttle body crank the engine if it backfires real bad 9 out of ten times its jumped timing issue from what ive experienced .
How good were those machine shop cam adapters? I used stephen max adapters and the dowel pin broke causing the motor to die (no start)
Finkle
09-27-2015 09:53 PM
cmpowell86
08-10-2015 12:35 AM
