Got my engine put in.. NO SPARK
Ok so this post is similar to the "No Spark" post on 9-11.
I finally got my engine in a couple of days ago. But I'm not getting a spark out of any of the plugs. When I try to crank my car, it tries to start, even smoke comes out of the headers(y-pipe not in yet). Also, all the injectors are clicking.
Any ideas?
Any ideas?
Ok, so I changed all my coils and spark plugs. Still no spark. I also switched my crank and cam sensors, still no spark. My dad tested the plug wires with a multimeter and it had 11.something. So need more help.
You should probably check the FSM EC section related to the ignition signal
TROUBLE DIAGNOSIS FOR DTC P1320. There you will find some flow charts for troubleshooting no spark condition. Since you have a multimeter and appear to know how to use it this may help you make some progress. It also tells you how to check those sensors.
Here is the link:
http://www.boredmder.com/FSMs/Nissan/
Here is the link:
Sensor wire on the plug telling them not to spark? Ill add that one to the books...
Did you check for continuity on the cam and crank circuits?
Yes, it does 'pop' sometimes when i crank it. I just thought that was because my y-pipe isnt bolted on yet. What does that mean? So your saying run a wire from the negative batt terminal to the bell housing? Where at exactly?
I replaced all my coils with the ones from my old engine(because it cranked just fine) I also switched out the sensors too. No difference.
Man I'm dealing with the same thing right now, except my problem is no spark to just 2 cylinders. Come to find out I have a break in my engine harness somewhere, so Im running a new harness of just the signal wires to the coils.
Ah man that sucks. I would consider my harness is messed up but it worked fine with my old engine, and I'm getting power to my plug wires. Hope you figure it out.
Don'tt rule out a harness issue. Like has been said those 4th gen harnesses are prone to breaking. Plus since the motor has been pulled and the harness had moved all around it would not surprise me if a couple wires broke inside.
Exactly. My harness was fine before pulling the engine out too. I was extra careful and didnt touch the harness with the engine at all. The only time it was disturbed was bending it over out of the way.
Really? Daum man that sucks. I moved it just to put the engine in. So you guys think that may have happened? Is there anyway to figure out that for sure if thats it?
Had the same issue awhile back after a motor swap down to the popping sound, checked and chained everything and it ended up being the ECU I don't know how when it worked fine with the old motor but I swapped that and it started right up. If all else fails give that a shot.
Maxima 4D you are completely wrong. A good ground is essential especially when his issues appears to be electrical. If the 2 wires for ur ECU aren't grounded your motor isn't going to fire up. Have you connected an OBDII reader and try cranking it? This may help close a circuit and help diagnose a ground issue as it did for my 2K swap
