HELP! getting only 265 miles on full tank
Old 09-18-2011, 06:11 PM
01max5spd's Avatar
i only get 265 miles on a full tank doing all city driving. im not sure if this is normal. how many do you 4th gen owners out there get with all city driving?
01max5spd is offline
Old 09-18-2011, 06:24 PM
LIMaxima's Avatar
I get about 325 to the tank with a lot of local mileage. Mine dropped to quite a bit when my knock sensor went bad, did you check for codes?
LIMaxima is offline
Old 09-18-2011, 06:36 PM
boost me.....
96blackmaxSE's Avatar
You're throwing codes or missing a lightbulb in your cell...check and respond! lol
96blackmaxSE is offline
Old 09-18-2011, 07:13 PM
beegeezy's Avatar
Do you have a 4th gen or a 5th gen?
beegeezy is offline
Old 09-18-2011, 07:35 PM
MOHFpro90's Avatar
320 is about normal for city driving.
MOHFpro90 is offline
Old 09-18-2011, 08:01 PM
SandyMax96's Avatar
Knock sensor is a usual suspect in these types of situation. Pre-knock sensor fixed I was getting 15MPG So you might want to check just like LIMaxima posted.
Also, are you doing moderate driving, conservative or jack-rabbitting? It all depends if you're in stop and go traffic or running in a hurry everywhere and flooring it.
Post up specifics!
SandyMax96 is offline
Old 09-18-2011, 08:12 PM
Rods03Max619's Avatar
Damn I like those numbers for city driving..
Rods03Max619 is offline
Old 09-18-2011, 08:56 PM
djkevinnn's Avatar
Me too, 250 if i'm lucky...
djkevinnn is offline
Old 09-18-2011, 09:25 PM
SandyMax96's Avatar
I usuallly get at least 310 when doing mixed city/hwy.
I do love when I get 410 from mostly all hwy and driving like a granpa though
Old 09-18-2011, 09:43 PM
beegeezy's Avatar
Miles per tank is irrelevant. MPG is the only important part of this discussion. OP, what is your MPG? A good running 4th gen 5-spd should get 18-20 mpg when only driving in the city. (all stop and go traffic) If you're getting significantly less then you need to fix your car.
/thread
beegeezy is offline
Old 09-19-2011, 09:45 AM
01max5spd's Avatar
i have a 4th gen, auto.
Old 09-19-2011, 09:59 AM
Closetcanibal's Avatar
i get 22.56 MPG combined since its my everywhere car 95 gle 5-spd
Closetcanibal is offline
Old 09-19-2011, 10:12 AM
OP, figure out your MPG and get back to us.
ChrisMan287 is offline
Old 09-19-2011, 10:30 AM
DIAMONDS98SE's Avatar
I usually shoot for 100 miles per quarter tank. Thats mostly city, and at least one redline per trip I generally get around 25 MPG, but Ive had anywhere from 19 to 31 MPG
DIAMONDS98SE is offline
Old 09-19-2011, 10:33 AM
ajm8127's Avatar
That's just ridiculous. I got 31+ mpg in a fourth gen auto doing 75 the entire tank. It was like 450+ miles on that tank.
I get almost 400 every tank (25+ mpg) with 50/50 mixed driving. I would expect around 325 with all city driving.
The OP's mileage is low for some reason. Checking for codes (as recommend above) is a good place to start. I would recommend using a code reader unless you are sure your CEL bulb works. It should come on with the ignition key "ON" but the engine not yet started.
ajm8127 is offline
Old 09-19-2011, 01:27 PM
VisciousMo's Avatar
General maintenance such as knock sensor, fuel filter, cleaning my air filter, fuel injector cleaner, and cleaning out my EGR tube+ TB got me better results. There are gobs of info on this topic
I put 18's on my car, set me back a little.
VisciousMo is offline
Old 09-19-2011, 08:34 PM
01max5spd's Avatar
I don't see no CEL with the key in the on position. Also, what is the most accurate way to calculate my MPG?
Old 09-19-2011, 08:46 PM
SandyMax96's Avatar
If your bulb is out, you'll have to use a code reader to get codes if you happen to have them, which I would think you do.
And to calculate your MPGs, first top off, reset the trip odometer, drive around until your next fill-up near empty and see how much it takes to fill up, which should be between 15-16.5 gallons. Then it's just simple math;
(miles on trip odometer) ÷ (gallons filled up with) = MPG
Old 09-19-2011, 08:53 PM
armatis's Avatar
1. Fill up your tank, write down mileage.
2. Drive your car, and when it gets low, fill it up again, write down both how many gallons you put in, and write down mileage again.
3. Subtract old mileage from new mileage.
3. Divide number of miles driven by number of gallons you put in to fill it up.
(miles/gallons=mpg)
armatis is offline
Old 09-19-2011, 09:00 PM
So your bulb is out. Run down to Autozone and get the car scanned. I wonder what codes you've got.
Old 09-20-2011, 12:47 PM
01max5spd's Avatar
i will run down to autozone tomorrow to see what codes i get and will update you guys tomorrow!
Old 09-20-2011, 07:48 PM
saig's Avatar
4th gen has 18.5 gal tank, so miles per tank (range) vs miles per gallon are
20 370
25 462.5
30 555
31 573.5
Official mileage is 27-28 (500-510mile range). Yours are at 265 mile range, equiv. to 14.32MPG, so it is not close to the specs.
Mine is 28 for unspirited driving.
saig is offline
Old 09-20-2011, 07:54 PM
saig's Avatar
20 370
25 462.5
30 555
31 573.5
That range calculation is ideal. When you are with full tank, you carry unwanted fuel weight. If you are almost empty, that give you best mileage out of the car.
saig is offline
Old 09-20-2011, 08:29 PM
The6spdMax's Avatar
Wow...
I get around 400... rush/non rush hour traffic and some locals.
The6spdMax is offline
Old 09-20-2011, 08:41 PM
beegeezy's Avatar
That calculation is ideal and pointless. You can't use the whole tank unless you want to drive around with an emergency gas can. But who would want to do that?
Nothing good will come from driving the car to the brink of fuel capacity. Fill up when your low fuel light comes on or asap after it does. Miles to the tank is also meaningless in stop and go city driving. What happens when you are in heavy traffic and just idling all the time? (mpg is biased then too) MPG is much more valuable of a barometer for running condition than miles per tank.
beegeezy is offline
Old 09-21-2011, 08:53 AM
01max5spd's Avatar
after my fuel light comes on, i usually drive for about another 15-20 miles to try to use most of whats left in the tank. then when i go to fill up i cant pump no more than about 16.5 gallons! i guess the other 2 gallons or so just sit in there and doesnt get used? maybe thats why my mpg is so crappy
Old 09-21-2011, 09:03 AM
SandyMax96's Avatar
My fuel warning light doesn't work
Old 09-21-2011, 10:37 AM
01max5spd's Avatar
ran to autozone today, got scanned, and im getting a P0302. i dont know where to start investigating. maybe start off by replacing plugs and wires??
Old 09-21-2011, 10:38 AM
beegeezy's Avatar
http://wiki.answers.com/Q/Is_it_bett...r_almost_empty
Your mpg has nothing to do with when you decide to fill up. Again, it's mile driven / gallons consumed. This is like 5th grade math.
It's your car guys, do what you want to do. I prefer to keep my fuel pump working and I don't like clogging my fuel filter.
beegeezy is offline
Old 09-21-2011, 10:39 AM
flthere's Avatar
I get in the range of 310-350 in the combined highway/local driving ... i suppose i don't need to check the codes for bad knock sensor looking at the numbers everyone is getting.
flthere is offline
Old 09-21-2011, 10:45 AM
beegeezy's Avatar
We have coil-on-plug ignition systems. You don't need to change spark plug wires b/c we don't have them. Spark plugs can be checked very easily and P0302 is a cylinder #2 misfire...so I know which plug I'd check first. You more than likely have a dying coil though.
beegeezy is offline
Old 09-21-2011, 11:39 AM
ajm8127's Avatar
I would start off by pulling all of the plugs and checking them. Replace them if you cannot remember when you last replaced them. Pay particular attention to cyl #2 because of the code you got. Install new plugs (with a torque wrench!), reset the codes and drive. Run a tank of gas, check you mileage, then check your codes.
ajm8127 is offline
Old 09-21-2011, 11:41 AM
01max5spd's Avatar
sorry for being such a noob but what plugs should i check first?
Old 09-21-2011, 11:45 AM
beegeezy's Avatar
Cylinder #2.
Do what ajm8127 said, check all of them. Six ngk copper plugs are only like $12. Fix your check engine light too...
beegeezy is offline
Old 09-21-2011, 12:05 PM
shuhengzhao's Avatar
Cylinder #2.
Agreed. Mine is 6th gen. After fixing oil injection, the mileage goes down to normal like one tank for 400 miles.
shuhengzhao is offline
Old 09-21-2011, 01:04 PM
cashoit's Avatar
@ the noobiness in this thread.
This has FAIL all over it.
"how do i calc miles per gallon"???? i mean cmon...REALLY
cashoit is offline
Old 09-21-2011, 05:07 PM
Bobo's Avatar
It could be an ignition coil, but it could also be a fuel injector.
I had a problem in May 2010 less than 10 miles after using a bottle of Chevron Techron fuel system cleaner and got a P0305 code. I replaced a spark plug and ignition coil. That was not the problem. I took the coil back and ended up having to replace a fuel injector. It got plugged somehow when the fuel system cleaner dislodged something.
I know of a place I am going to take it to that can test it and clean it somehow for $25 and I will keep it for a backup.
Bobo is offline
Old 09-21-2011, 07:04 PM
beegeezy's Avatar
This thread has lowered my iq by newb osmosis.
beegeezy is offline
Old 09-24-2011, 10:26 AM
gerber2022's Avatar
Last night coming back home from work i began from hawkings texas passed the traffic of austin texas and also san antonio traffic as well made it to freer texas plus racing some honda's among the way going about 85 75 on a 96 5 spd i got about 435 miles to the tank getting about 27 or 28 miles i say not bad for a 205355 miles on the car
gerber2022 is offline
Old 10-04-2011, 06:47 PM
max-r95's Avatar
I get 270 If I'm lucky :/
max-r95 is offline
Quick Reply: HELP! getting only 265 miles on full tank
