Maxima gauges HELP!!
Alright so I bought these reverse glow gauges from paradox-systems.com. As you can see I don't know why the freaking needle gets stuck on 30 when idle and doesn't go down from there(ever). After I pass 30 the needle starts moving and I really need help with this from someone that knows what there doing please!!! Also I choose from the desired options on the gauges but it always goes back to the first one which I don't want because I want the one on the picture, so that when I turn on the lights that one comes on and not the first one.
Please I would really much appreciate anybodies help and thank you
The site where I bought these are:
http://www.paradox-systems.com/produ...products_id=74
This is while the car is off and just the lights are on.
well they pop off but the whole thing does like usual.
What do you mean? and no the needle isn't bent
I have read about problems like your having when installing those indiglos. Make sure that the gauges are not bubbling up slightly at any area around the surface of the gauge. That will cause the needle to not move. So around the 30 mph area the gauge is not flush thus causing sticking in that area.
Alright so this is the deal the needle never goes down under 30 and when im going faster it moves but when im on the freeway it skips into the right speed so the needle like jumps forward to like 60 or so depending on the speed im going, so this is what im trying to figure out.
Eh? It resets itself, well my 99 SE-L cluster did anyways.
