No Spark
Old 09-11-2011, 07:34 PM
Turbo 4th Gen
93altima's Avatar
No Spark
Well Just bought the car not getting any spark... iam getting fuel i changed both crank sensors and cam sensor, added extra grounds, tried starting fluid, changed the ignition switch new starter and battery, car does crank
the coil packs are getting voltage and so are the injectors
Security light flashes but turns off while cranking
Cel is on when in the ON position
Car specs
98 GXE or GLE
De-k Swaped ( car did run with this motor already)
Auto
etc
93altima is offline
Old 09-11-2011, 09:33 PM
Xfactor22's Avatar
wow, got me me. i thought of a few things but you changed everything i thought of and more. good luck with this puzzle man.
Xfactor22 is offline
Old 09-11-2011, 09:52 PM
Any codes?
ChrisMan287 is offline
Old 09-11-2011, 09:53 PM
pflicht's Avatar
Try testing each coil pack to a metal source to see if they are sparking? Just because the coil are receiving voltage doesn't necessarily mean that they are working or working optimally. Also have you checked the spark plugs themselves for corrosion on the terminals and the main part too?
IDK what to say, just giving my $.02 to try and help
pflicht is offline
MaximaSpd85's Avatar
how bout the two grounds on the front of the intake manifold?
MaximaSpd85 is offline
Old 09-11-2011, 09:57 PM
I thought those were for the KS?
Old 09-11-2011, 10:42 PM
Dark_man_x's Avatar
Injectors I believe. But none the less check all grounds. Also check for continuity on the crank and cam sensor circuits, The sensors may be good but not relaying the information back to the ECU. 4th gens sometimes have issues with the harness breaking where it turns to go into the firewall. Especially with it being a DEK swap means that the harness has been moved around soo.
Dark_man_x is offline
Old 09-12-2011, 05:22 AM
Turbo 4th Gen
93altima's Avatar
Any codes?
havent checked codes yet
93altima is offline
Old 09-12-2011, 05:23 AM
Turbo 4th Gen
93altima's Avatar
i tried each coil ppack none are sparking
93altima is offline
Old 09-12-2011, 05:24 AM
Turbo 4th Gen
93altima's Avatar
i grounded those to the dek location and added an extension to the body
93altima is offline
Old 09-12-2011, 05:27 AM
Turbo 4th Gen
93altima's Avatar
i checked and added grounds, but i dont know how to check continuity to the sensors
93altima is offline
Old 09-12-2011, 06:01 AM
cashoit's Avatar
gotta start looking thru the FSM for test procedures.
I think your ECU isnt firing coils. THats a problem man
cashoit is offline
Old 09-13-2011, 05:56 AM
Turbo 4th Gen
93altima's Avatar
tried a working ecu from my boys car and still nothing
93altima is offline
Old 09-13-2011, 07:37 AM
cashoit's Avatar
Have verified that each coil is gettin sufficient voltage. If its cranking then that means the starting circuit is good.
A Bad MAF would still let the car start. Unless u shorted a bunch of wires for the coils or CPS or CKPS, im stumped
cashoit is offline
Old 09-14-2011, 05:13 AM
Turbo 4th Gen
93altima's Avatar
im going to buy a multimeter today
93altima is offline
Old 09-14-2011, 11:50 AM
Dark_man_x's Avatar
Good. A good multimeter is worth its weight in gold when it comes to finding electrical issues. Look through the FSM and it should tell you the procedure for checking continuity on those circuits.
Old 09-15-2011, 05:47 AM
Turbo 4th Gen
93altima's Avatar
well i tested the voltage to the coil plugs and its getting 12v but yet no spark WTF
93altima is offline
Old 09-15-2011, 08:04 AM
cashoit's Avatar
hmmm... since u not gettin a cel, i dont believe the coils are busted, test resistance across the coil. Should be more than zero.
cashoit is offline
Old 09-15-2011, 12:29 PM
Turbo 4th Gen
93altima's Avatar
well i tried with a new set of coils from my friends car that he drove to my house and still no spark
93altima is offline
Old 09-15-2011, 01:01 PM
Maybe it's a problem with the ECU?
Old 09-15-2011, 01:15 PM
Kevlo for President
Kevlo911's Avatar
He tried another ECU...
Check the power transistor on the coil circuit.
Kevlo911 is offline
Old 09-15-2011, 02:15 PM
My apologies, I didn't see that.
Old 09-15-2011, 04:48 PM
jholley's Avatar
Checking those cel codes could narrow down this problem.
Now that you have a multimeter I would check for continuity between the crank sensors and ECU. You'll need wire jumpers for extension. The FSM lays out the wiring diagram.
jholley is offline
Old 09-15-2011, 05:11 PM
Dark_man_x's Avatar
Finally, someone else that has the same idea as I did.
Old 09-15-2011, 05:58 PM
Turbo 4th Gen
93altima's Avatar
how? and where is that?
only emission codes, and a idle air code and ill do that next
93altima is offline
Old 09-17-2011, 09:24 AM
Turbo 4th Gen
93altima's Avatar
i just purchased a whole parts car for little to nothing so i will be swaping out the engine harness today
93altima is offline
Old 09-17-2011, 04:25 PM
max95q's Avatar
Subscribed to this thread. My 95 with normal vq has the same symptoms and Ive done just about all that he has done except harness swap and ECU change over. Its boggling because the car only has 133k miles.
max95q is offline
Old 09-17-2011, 04:45 PM
100% chingon
clive's Avatar
The one absolutely certain way to see what's happening is to either get hold of someone with an oscilloscope or tow it to a garage that has a computer tune-up system, the type that has a scope that shows the ignition traces.
If you put the scope input on the hot side of each coil pack in turn, you should see a spike waveform when the motor is cranked. If not, then either the ECU power output stage is fried, or the wiring harness, or both.
I was looking to buy a Sentra SE-R VI that had the same fault, it turned out the ECU was bad, the guy put a replacement in and it must have had a bad harness because it blew the second ECU as well. He was well pissed off.
As a quick test you MIGHT - I have never tried it - put a neon tester on the hot side of the coil and see if it pulses.
clive is offline
Old 09-19-2011, 11:49 AM
Phx_Max's Avatar
any update on this?? ive had my maxima sitting for a very long time onthis same issue. my car was running just fine. and all of a sudden one day going to work sputtered and turned off on me. i would try turning it back on and it did at first and i drove it for another few blocks and turned off again and wouldnt turn on any more. took it home and no spark. didnt really get to much help last time i asked. so its been sitting. im going to start working on it again with the thing mentioned above but if you find a solution let us all know what it was plz
Thx
Phx_Max is offline
Old 09-19-2011, 12:02 PM
aackshun's Avatar
Did you check the fuses for the ECM? It's like #1 and #2 on the under hood fusebox on the right (driver side) of the car....
aackshun is offline
Old 09-21-2011, 08:41 PM
Turbo 4th Gen
93altima's Avatar
ok ive changed the full engine harness and a new ecu pulled from a running parts car and still nothing changed all relays and checked every fuse still nothing, next is im switching out the lightweight crank pully for a stock one, then compression check, then body harness if nothing after that a brick thru the front windshield
this is my 3rd 4th gen and ive never been through any bull**** like this before
93altima is offline
Old 09-21-2011, 09:27 PM
Have you checked your grounds?
Old 09-22-2011, 07:54 AM
Turbo 4th Gen
93altima's Avatar
ive checked and added grounds
93altima is offline
Old 09-22-2011, 08:07 AM
KH3 by popular demand
maxgtr2000's Avatar
To verify spark I would hook up a coil pack with a spark plug and have some one crank it to visibly see the spark. If the plugs are old they could be shot. If you get spark, verify the injectors are spraying/fuel pump fuse is in and pump working. If there is an afpr make sure it is adjusted to the proper pressure. If there is no spark check the 2 crank sensors. If none of this works send me the 00vi .
maxgtr2000 is offline
Old 09-22-2011, 11:25 AM
Turbo 4th Gen
93altima's Avatar
did the spark plug check already, the injectors are firing, changed both cranks sensors from a runnin car........Correction its a 00vi w/ a pathy TB and adapter plates
93altima is offline
Old 09-30-2011, 08:19 PM
ajcool2's Avatar
Jean that car has a switch on the dash that will cause the car not to start. We had the same problem when we did the DEK swap on it. I beleive its under the dash to the right.
ajcool2 is offline
Old 10-01-2011, 10:29 AM
Turbo 4th Gen
93altima's Avatar
i already done removed the whole alarm system, i just put in a new motor so ill see if it starts today
93altima is offline
Old 10-01-2011, 10:59 AM
TurboA32's Avatar
wheres that switch at driver or pass side? and do the 96 maxs have it? you already know im in the same boat as you
TurboA32 is offline
Old 10-02-2011, 08:15 PM
TurboA32's Avatar
Where is this located exactly
TurboA32 is offline
Old 10-02-2011, 10:13 PM
AllMaxxedOut's Avatar
Any luck???
AllMaxxedOut is offline
Quick Reply: No Spark
