my car is jumping at stops
Old 08-30-2011, 03:52 PM
joseph.mcgowen's Avatar
i got a 96 auto and when i stop at a light it feels like my motor is jumping.at first it was only at lights and now it does it while i am driving some times.some times it feels like it is gonna stall on me. there are no cel codes either. i was told it was my torque converter and then i was told it could be bad fuel injectors also. i am stumped any input will help, and when i first get in to go anywhere it takes a minute to star the car i have to keep turning the key then letting off then turning it over again i have to do that 2 or 3 times before it will start
joseph.mcgowen is offline
Old 08-30-2011, 04:02 PM
CEL on?
ChrisMan287 is offline
Old 08-30-2011, 04:28 PM
tigersharkdude's Avatar
Question: Say you have a hard time starting, and get it started, cut the car off, will come right on? or do you have to try cranking it multiple times?
tigersharkdude is offline
Old 08-30-2011, 09:57 PM
BronxSleeperMax187's Avatar
sounds like a misfire...coils\plugs been changed ever?
BronxSleeperMax187 is offline
Old 08-31-2011, 06:19 AM
cashoit's Avatar
sounds like one of the crank sensors. Prolly rear crank sensor. Test both and CPS.
Remember a resistance test with the crank sensor tells u nothing. The test for the CKPS is a voltage test.
cashoit is offline
Old 08-31-2011, 06:50 AM
njmaxseltd's Avatar
Definitely a misfire.
Causes:
1) Fuel injector
2) Spark Plug
3) Coil Pack
I'm willing to guess it's ignition related **cough*** coil pack...
njmaxseltd is offline
Old 08-31-2011, 07:06 PM
@ nj max its not a misfire but it does almost feel like one and i have done all my coil packs and plugs but not injectors yet and no cel
@ cashoit where are the crank sensors and if you have what the resistance should be that would help
@ tigersharkdude just have to keep cranking but this morning before i went to work it shut off when i put it in reverse and pressed the gas but that is the first time it has done that
Old 09-01-2011, 12:35 PM
cashoit's Avatar
i assume you have already cleaned TB and MAF, replaced PCV and ECTS.
Read my earlier post. A resistacnce test tells u nothing about the crank sensors. Test for the cranks is a voltage test.
The test for the Camshaft postiion sensor is a resistance test
cashoit is offline
Old 09-01-2011, 08:10 PM
@ CASHOIT my bad i wasnt thinkin when i replied and it is probably my camshaft position sensor because oil is leaking from around it i didnt realize that until today when i went to look
Old 09-01-2011, 08:43 PM
oil leak there is common, just change the O-ring
Old 09-02-2011, 02:45 AM
MaxJammin's Avatar
i have this problem too, i have a cyl 1 misfire...and a solenoid A trans code, either way... i replaced the coil and the plug, next step is the injector...not lookin forward to doin it, DO'H
MaxJammin is offline
Old 09-02-2011, 05:00 PM
so the oil dont mean my camshaft position sensor is bad?and i tried to get the o-ring today but they dont carry it at autozone anyone know where to get it
and @ maxjamin i am throwing no codes it has been scanned multiple times when i first the bought the car i threw a p0731 (1st gear malfunction) but that just went away other than that any codes that have been thrown were fixed so i dont think it is a miss but i might as well try an injector to
Old 09-04-2011, 02:05 AM
MaxJammin's Avatar
well, i would say compression test it, and change the plugs/coils and then maybe the injector, im just gunna live with it untill next year (cars goin under the knife BIG TIME
Old 09-06-2011, 12:20 PM
bobflood's Avatar
so the oil dont mean my camshaft position sensor is bad?and i tried to get the o-ring today but they dont carry it at autozone anyone know where to get it?
Got it at the dealer - cost $4.
bobflood is offline
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
Costa068
08-17-2015 02:13 PM
doobadoo
08-15-2015 06:43 PM
kirkhilles
08-08-2015 10:53 AM
Quick Reply: my car is jumping at stops
