Camshaft Position Sensor
The camshaft position sensor is located on the front timing chain cover. Facing the passenger side of the engine it's the sensor located a couple inches to the right of the side engine mount and a couple inches directly above the adjuster for the pulley to the AC and alternator belt. There is nothing else in that area. Don't know the tool yet though.
A 10 mm socket and a long thin screwdriver for the connector
The ckps that was mentioned above is for top dead center ONLY not ignition timing that one is located next to the transmission bell housing behind the radiator on the engine block one 10 mm bolt an a 3 wire connector
Use the long thin flathead to gently pry the connector and sensor apart DO NOT damage the connector
I hope this helps
I hope this helps
Yea theres no need to replace it if its still functioning. Once you remove it youll see an o-ring at the end of it..you can remove the o-ring and take both the ring and sensor to a hardware store to find an oring which will fit properly at the end of the sensor..then pop it back in..done deal...Quick cheap EASY fix...
I hope this helps
I hope this helps
TallTom
50
07-08-2022 09:54 AM
my03maxima
04-29-2020 12:48 AM
Kyle Lee Cleveland
09-28-2015 09:01 PM
