MAP/BARO switch solenoid valve and MAP sensor dissed
Old 08-03-2011, 03:54 PM
100% chingon
clive's Avatar
My car has a broken MAP/Baro switch solenoid valve. Yes it has taken me ages to discover this. The car runs fine. . .
On this diagram, (part 5 in the upper diagram) the top hose shown is dangling in the air because the inlet port on the valve is broken off, and the lower port on the valve has been sealed (by someone other than me) with sealant, presumably because the plastic bit is also broken off.
I'll have to see if any org members have one for sale, but in the meantime, does anyone know what - if any - effect this problem has on performance or whatever? Thanks.
clive is offline
Old 08-04-2011, 05:06 AM
ajm8127's Avatar
I don't really think the ability to read either is important as long as the MAF is working. The computer probably looks at the manifold absolute pressure and can check if the mass-airflow sensor reading is valid based on the barometric absolute pressure. In other words, I think the ability to read MAP/BARO is for diagnostic purposes only.
ajm8127 is offline
Old 08-04-2011, 08:25 AM
100% chingon
clive's Avatar
Thanks. I think I will try to find one anyway. I hate having broken bits.
clive is offline
Old 08-04-2011, 10:58 AM
ajm8127's Avatar
Don't get me wrong, you should definitely repair it. I thought the question pertained to the period of time before you could fix it.
ajm8127 is offline
Old 08-06-2011, 05:09 PM
100% chingon
clive's Avatar
Ah! No. The previous owner "arranged" that. I definitely want to fix it.
clive is offline
Old 08-06-2011, 05:24 PM
neocry's Avatar
Clive,
What year is your car? I've pulled one from a junk yard 5 months ago, but didn't need it due to the fact my problem was that the wire snapped off.
PM me with your address. I can ship it to you.
neocry is offline
mvm062
11-30-2020 09:00 AM
Max139617
09-20-2015 07:25 PM
DarjeelingRose
09-15-2015 01:20 AM
tardrex
09-11-2015 07:35 PM
dcardello
09-03-2015 11:44 PM
Quick Reply: MAP/BARO switch solenoid valve and MAP sensor dissed
