Installing Factory Keyless Entry
I have a 1996 SE with manual AC, manual seats, no Bose, and no keyless entry. How hard would it be to add the factory keyless entry? I've already searched and can't really find a solid answer. Would it be as simple as buying a fob from ebay and programming it?
Btw, I have an aftermarket remote starter/keyless kit that I have NOT installed. If I use the aftermarket kit, would I still be able to remotely open the windows by holding down unlock or do I need the OEM keyless?
If im not mistaken, you do have the keyless entry just no remote, If you have a after market alarm then why worry about the keyless? Im pretty sure you dont want to carry around 2 remotes, 1 just so you can roll the window down, or do ya?
Here is how it works...
First u need to ascertain whether or not u have factory keyless entry. A quick call to nissan with your VIN will answer that.
If u dont have a system, then u need to buy an aftermarket system and have it installed. Costs like 30-50 bucks. but u might as well get an alarm system that comes with keyless. Cost me 80 bucks for the system plus install last year.
If u do have a factory system, then jus have nissan provide u with instructions for programming a new key.
If you don't already have factory key less entry, installing it looks like a can of worms. The BCMs look like they are different, you'd need the key less control module, and by that time you would have already spent 1500 USD new. Of course you could get them from a junk yard, but the harnesses may be different as well (but from the looks of courtesyparts.com, they are not). You could probably save yourself a lot of headache by getting an aftermarket alarm system. The windows might not roll down, but you'd have key less entry and an alarm. Some aftermarket systems may have the ability to roll down the windows. You'd have to check into that.
It would definitely not be as simple as buying a key FOB and programming it.
If you do have an SE, you should be pre-wired and should be able to add it in. The harnesses for the control box should be in the trunk. The sensor for the hood is taped up behind driver's headlight. The only harness that may not be there is the one for the security light. My 95 GXE has the harnesses taped up but haven't attempted to add it in but I believe its possible.
MaxLife17
06-27-2019 01:37 PM
