Service engine light keeps reappearing
Old 07-21-2011, 02:44 PM
holymoly's Avatar
Just after doing a TB and MAF cleanup, suddenly the service engine engine keeps reappearing, even after the diagnostic 0505 indicates all clear.
After clearing the code, the service engine light comes back.
Any ideas?
holymoly is offline
Old 07-21-2011, 03:03 PM
Stagnet04's Avatar
you need to go get it scanned with one of those diagnostic scanners. If your lucky, Autozone in your area can still do it for you for free. This happened to me where the 0505 code kept coming up. I finally got it scanned and it turned out to be an 02 sensor that was intermittently failing....
Stagnet04 is offline
Old 07-22-2011, 08:04 PM
holymoly's Avatar
had a scan done by one of those hand held devices, showed nothing.
Autozone, I'm passing though the US next week, has a real scanner, not hand-held?
holymoly is offline
Old 07-23-2011, 07:44 AM
MOHFpro90's Avatar
The autozone scanner is still a handheld Actron or similar.
If I am not mistaken, the oxygen sensors are the only thing that can cause the MIL to come on and off.
MOHFpro90 is offline
Old 07-23-2011, 08:37 AM
holymoly's Avatar
I changed the bottom oxygen sensor near the catalytic converter last year, so its the upstream left and right in the engien compartment?
Interesting that all this started just after I cleaned the throttle and MAF. Maybe a vacuum leak, there is a little bit of idle.
Only the dealer can really do a proper scan?
holymoly is offline
Old 07-23-2011, 09:40 AM
MOHFpro90's Avatar
Not true. Go to advanced/autozone, their scanner may pick up something that another handheld does not.
Then call around to local shops. Ask if anyone has a Modus, Verus, or any other computer based scan tool. They're more comprehensive in their coverage.
Old 07-25-2011, 10:32 AM
Swazey's Avatar
I have an evap leak somewhere and that triggers my MIL to come on. Sometimes it turns on, other times it stays off. when i turn the screw on the ecm to read the code, nothing comes up. when i use a code reader, the code that is stored is for an evap circuit fault.
not sure why it is happening but my evap leak causes my MIL to come on and off.
Swazey is offline
Old 07-25-2011, 02:59 PM
MOHFpro90's Avatar
The turning of the screw method, from what I know, reads active DTCs. It wont read stored codes, which is why you got nothing until using the scanner.
Not sure why it causes the MIL to turn on and off, guess I was wrong.
Old 07-25-2011, 05:03 PM
holymoly's Avatar
I am unable to find advanced/autozone shops.
You have a website?
holymoly is offline
Old 07-25-2011, 06:27 PM
MOHFpro90's Avatar
Might try Carquest and see what they can do. Not sure if any of the other auto parts places up there in Ontario have the free services like in the states.
Old 07-26-2011, 04:49 AM
holymoly's Avatar
I'll be passing thru the US, east of Buffalo, this long weekend, so any free non hand held computer scans are welcome.
I hope the car should hold out, a likely O2 sensor can wait.
holymoly is offline
Old 07-26-2011, 06:54 AM
Whatchyou say?
JtzMax's Avatar
UIM or LIM leak will also do this, and it can give several different codes. Most likely, the code you'll get will be 0174 or 0175 (oxy sensor). I've been having this issue for a LONG time now and my mpg's suck, but I'm not too worried about it and when I find the time, I'll do the IM gaskets.
JtzMax is offline
Old 07-26-2011, 07:48 AM
cashoit's Avatar
I thought misfires would cause MIL to flash. IIRC
cashoit is offline
Old 07-26-2011, 09:08 AM
holymoly's Avatar
UIM or LIM leak?
Just remember, all this started just after I did a throttle body and MAF sensor clean. Pretty sure I reassembled evertyhing...
holymoly is offline
Old 07-26-2011, 03:11 PM
Whatchyou say?
JtzMax's Avatar
Originally Posted by holymoly
UIM or LIM leak?
Did you replace the gasket for the TB? Any possible leaks from the vacuum hoses? Sometimes the end of the hose might look ok, but it can be split and causing a leak.
JtzMax is offline
Old 07-26-2011, 05:30 PM
holymoly's Avatar
Yes the gasket was replaced, and just checked for any hose leaks. None
Good point.
holymoly is offline
Old 07-26-2011, 07:53 PM
MOHFpro90's Avatar
Misfires will cause the MIL to flash, not for it to turn on and off intermittently.
On your way through the US, check Advanced Auto Parts or Autozone.
Old 07-27-2011, 04:50 PM
holymoly's Avatar
Did a another OBC check and a 13-02 code was returned.
Manifold Absolute Pressure (MAP) solenoid valve or circuit fault.
I will pick one up at Autozone for $80.
Does this require an immediate fix?
holymoly is offline
Old 07-28-2011, 09:39 AM
holymoly's Avatar
bump*
am I right on the price, as well?
holymoly is offline
Old 07-28-2011, 10:44 AM
cashoit's Avatar
hit the JY and jus swipe a few of them for like 10 bucks. thas what i did when i had the code.
cashoit is offline
Old 08-04-2011, 08:08 AM
holymoly's Avatar
well I'm back from the states, had scans done at both Autozone and Advanced Auto. They look like Partsource up here only better.
Both were showing MAP sensor and EGR value flags.
But I informed the guy all this happens just after I do a TB clean.
He tells me don't change anything and look for vacuum leaks.
Sure enough, the air inlet duct small hose was not connected, it was instead connected to the inlet at the TB, who short hose was hidden behind all this.
I say this as this Britney (I did it again) moment can happen to you too.
P.S. Service engine soon light mysteriously disappeared.
holymoly is offline
Old 08-11-2011, 05:18 PM
pc99maxima's Avatar
i just had changed my knock sensor and all 3 of my o2 sensors (my car is federal emissions) and now i have a code for evap .... how would i find out where this 'leak' is and how to get the ses light off so i can pass ny inspection!??!
pc99maxima is offline
Old 08-12-2011, 09:50 AM
bobflood's Avatar
Several different evap codes that point to different things. Would help if you post actual codes.
bobflood is offline
Old 08-12-2011, 01:33 PM
holymoly's Avatar
As in my case, DIY I forgot a key hose when reassembling. Hence a service engine code, this doesn't necessarily translate that that part is defective but saying something is out of wack.
Keep checking you got evertyhing back where its supposed to be.
holymoly is offline
CorollaULEV
30
08-09-2021 08:11 PM
Dennis Twohy
10-01-2015 06:01 PM
Justinmc760
08-23-2015 03:10 AM
maxinout93
08-20-2015 02:17 AM
Flores94
08-11-2015 12:53 PM
Quick Reply: Service engine light keeps reappearing
