help 98-99 cluster swap in my 97
Old 07-12-2011, 08:54 PM
isandres8884's Avatar
i just swap my 97 cluster to a 98-99, everything its fine but i need a b+ wire, cuz every time i turn on my car the trip a and trip b resets by it self any help or advice
isandres8884 is offline
Old 07-12-2011, 10:11 PM
jplunks's Avatar
i have a 97 max and i wanted to change mine also...did you do it yourself? how did you get the odometer to match up?
jplunks is offline
Old 07-12-2011, 11:36 PM
styliztik's Avatar
you can't get the odometers to match up. the only way is to find one with close to what you have, or buy one with more miles on it, and change it out right when your current says the miles on the new one lol
styliztik is offline
Old 07-13-2011, 01:38 AM
Haishun Boi Max's Avatar
I want to do the samething, was it a direct swap?
Haishun Boi Max is offline
Old 07-13-2011, 02:10 AM
Maxima.org Insomniac
98SEBlackMax's Avatar
I did the swap years ago on my '96 to '98 digi gauges, forgot that I even did it at times until someone reminds me.
Anyways I tapped into the wire that powers the clock and that keeps the A & B trip odometers powered up. I forgot which color wire it was but I checked with my voltmeter with the car shut off and found the wire with 12 volts on it constantly.
Not impossible to change the mileage with basic electronics if you can find a replacement '98 ~ '99 digi cluster with lower miles to the '95 ~ ' 97 analog gauges you are swapping out. Fastest work bench ever!
So it is possible to match up the mileage with some electronics knowledge.
The Maxima has about 215K miles on it now and all the gauges still work. Though I do have to replace one of the bulbs that burned out a while back, sheer laziness on my part I guess.
NO! This requires rewiring about 25 wires behind the cluster. If you try to force the plugs into the digi cluster it will short out and damage the cluster.
98SEBlackMax is offline
Old 07-13-2011, 02:58 AM
lux97Max's Avatar
ive tried doing this as well, pita i wish they made adapter plugs for the 95-97's to convert to the plugs for the 98-99's
lux97Max is offline
Old 07-13-2011, 03:09 AM
Thanks, I guess imma stick to my 97 cluster
Old 07-13-2011, 09:28 AM
ill try to find the wire, not bad for the first time doin it lol.
Old 07-13-2011, 01:03 PM
Grn4thgen's Avatar
SICK Someone should do a write-up!
Grn4thgen is offline
Old 07-13-2011, 01:19 PM
thats right i agree with that
Old 07-13-2011, 04:38 PM
GarageToys's Avatar
Maybe I'm just old school but I like the look of the analog better (even though mine's digital).
GarageToys is offline
Old 04-18-2013, 03:00 PM
stone4779's Avatar
Hey will a 99 tach swap over into a 97 cluster?
Cuz I just bought one and I just realized the tach might not fit or wire up lol
The needle is orange on the new one I got, the old one I have is not. This new one has a TCS light too I just noticed
stone4779 is offline
Old 04-18-2013, 03:10 PM
eddie982's Avatar
I got a digital cluster with super low miles- 93k, pm if interested.
eddie982 is offline
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
JonBlz
10-05-2015 06:02 PM
ef9
10-04-2015 08:43 AM
HerpDerp1919
09-29-2015 02:02 PM
Quick Reply: help 98-99 cluster swap in my 97
