timing issues? camshaft position senor threw code...
Old 01-15-2012, 08:23 AM
nismo maximus's Avatar
a few weeks ago, my timing chain made some noise. i was assuming it was the tensioner. then 3 days ago, it threw code for camshaft position sensor. i hadnt replaced it yet though. but i did notice a loss in power.
then yesterday, on my way home to do an oil change, i stopped at oreilllys to get filter and seafoam. i added just a little bit to the oil. when i started my car, it ran like it had a stroker. the motor bogs. (my old maxima, 95, just recently started doing this. i know the lady who drives it)
so i checked coilpacks and maf. no difference. and i changed the camshaft position sensor, and it still has the problem. im thinking that since my timing chain made a rattle, assuming i needed to replace the chain tensioner, that overtime it has tweaked the timing just a bit. and now it needs some small timing adjustments.
i would search, but its a PITA because im using tab and arrows keys to surf the net.
do you guys have any input??
nismo maximus is offline
Old 01-15-2012, 08:30 AM
oh, if it helps, i just tried searching. nothing.
it has no power and takes forever to get up to speed. almost as if it is misfiring, but no codes for misfiring. the stealership said that i would have to take it in so they could reset my idle control (i forgot what he called it).
Old 01-15-2012, 08:47 AM
Just the tip.
JNCoRacer's Avatar
Any other codes besides the cam sensor?
JNCoRacer is offline
Old 01-15-2012, 10:18 AM
knock sensor. but thats been on for awhile.
Old 01-15-2012, 10:58 AM
Shift_A32B's Avatar
KS code = Retard Timing = Slow poop Max.
Don't ask how I know.
Shift_A32B is offline
Old 01-15-2012, 01:29 PM
njmaxseltd's Avatar
Knock sensor isn't going to cause drivability issues, most wouldn't even feel any difference in performance with defective ks.
Ignition timing is not adjustable on our cars.
The camshaft sensor controls fuel injector timing.
Does the timing chain still make noise? Was the noise only present at start up?
If the chain jumps the vq will run, but misfire on two cylinders. Are you getting a misfire or is it just a bog, loss of power?
Did you swap the maf or just check it with an ohm meter? How did you look at the actual signal from the maf?
Check fuel pressure.
Verify the maf is actually working.
Make sure the exhaust isn't plugged, bad cat?
It's very unusual for a vq to jump time, I don't think it's your issue.(yet)
njmaxseltd is offline
trasmadean
01-20-2018 05:05 AM
Finkle
09-27-2015 09:53 PM
Rage Maximus
09-03-2015 12:26 PM
homewrecker
08-24-2015 08:56 PM
wingnut2006
08-15-2015 04:16 PM
Quick Reply: timing issues? camshaft position senor threw code...
