Universal Boot
Old 06-23-2011, 07:02 PM
bassmann's Avatar
Universal Boot
Hi,is their a universal boot to cover the rack and pinion boot that is damaged? If so who sells them? Please help if you can.
Bass
bassmann is offline
Old 06-23-2011, 10:41 PM
max ride 41's Avatar
cheaper and easier to replace axle than to do just the boot.
max ride 41 is offline
Old 06-24-2011, 04:54 AM
ajm8127's Avatar
But the problem is the steering rack boot.
If I were you I would just buy a new boot. If you take careful measurements, you should be able to get the tie rod adjusted to the same length as it was when you removed the outer tie rod end to do the boot. Use some part of the tie rod as reference, for instance where the flats are cut on the rod for a wrench. I can't see it taking more than a hour from jacking your car up to torquing the lugs.
ajm8127 is offline
knight_yyz
11-01-2015 01:34 PM
londonflu
09-19-2015 02:33 PM
followthadollar
09-17-2015 06:31 PM
carid
09-09-2015 05:06 AM
Quick Reply: Universal Boot
