Stuck on strut knukle
Old 06-21-2011, 05:21 PM
bassmann's Avatar
Hi,I'm trying to install struts. They are already assembled I got the top in put nuts on. Now I'm stuck on the knukle part cant line it up with strut. It looks like it will not line up straight and be even with the holes. What am I doing wrong? Please help if you can.
Bass
bassmann is offline
Old 06-21-2011, 05:33 PM
SuperSlow_max's Avatar
u will need someone to pry down on the lower control arm, and get one bolt in the hole
SuperSlow_max is offline
Old 06-21-2011, 06:16 PM
neosmatrix's Avatar
I stood on the hub and while doing so slipped the bolt through the hole.
S
neosmatrix is offline
Old 06-21-2011, 06:32 PM
it's easier to get a pry bar and poke the hole
Old 06-21-2011, 07:28 PM
bassmann's Avatar
Do I put bar through top hole of strut and then try to get it in knuckle? How should I go about doing this? I screwed up top was easy now this. Car is sitting on jack stands probably for days heavy rain coming with lighting and thunder.
Bass
bassmann is offline
Old 06-21-2011, 08:25 PM
Conecarver
BEJAY1's Avatar
Unhook that sides sway bar linkage. Do the knuckle before you line up or tighten the top. Wiggle, light hammer tap in, pry out, repeat.
BEJAY1 is offline
Old 06-21-2011, 08:50 PM
gregmaxin's Avatar
i had this problem once when i was replacing my knuckle. i just stood on the lca while pulling up on the fender which caused it to move down and at the same time just had my lil brother stick both the bolts through when it lined up.
gregmaxin is offline
Old 06-21-2011, 09:38 PM
Bass
get a pry bar and pry down on the lower control arm so that the control are will move down, then have someone put a bolt through the spindle and shock.
Old 06-21-2011, 09:56 PM
MaxJammin's Avatar
this is the easiest!, i have done 2 sets of LCS, and 2 sets of struts, and this is how i did them, took 15 mins per side
MaxJammin is offline
Old 06-21-2011, 10:37 PM
You wouldn't have this problem if you raised the entire front end.
ChrisMan287 is offline
Old 06-22-2011, 07:53 AM
njmaxseltd's Avatar
Seriously people, common sense here. Both front wheels up in the air, off the ground, hanging, no load on the suspension - BOTH SIDES!!
njmaxseltd is offline
Old 06-22-2011, 08:17 AM
Jayson89NYC's Avatar
++1
Jayson89NYC is offline
Old 06-22-2011, 09:07 AM
Boosted Panda
Flava_24/7's Avatar
Ding,Ding,Ding,Ding,..... WINNAR!
Flava_24/7 is offline
Old 06-22-2011, 06:16 PM
bassmann's Avatar
Thanks guys,special thanks to chrisman287 and njmaxseltd. Jack up the whole front end. Wow knuckle went right in. Thanks a lot you guys are the best.
Bass
bassmann is offline
Old 06-22-2011, 11:52 PM
ef9
ef9's Avatar
Are you f'n serious? People actually tried to change struts without the front end up in the air?????????????
WOW.
ef9 is offline
Old 06-23-2011, 01:18 AM
Boothers96's Avatar
I had more issues with this on the pass side since i had to remove the axle nut and had to align the axle in the hub while lining up the strut bolt holes....drivers side wasnt as big of an issue.
S
This ^....just put ur foot on the hub or LCA and apply pressure w leg until holes line up.
Boothers96 is offline
Old 06-23-2011, 02:00 AM
Heero88's Avatar
O_O i just did this today and i had one side up not both all i did was remove the bolt holding the sway bar and down went the hub assembly then i aliened and tightened up all the bolts top and bottom of the strut the used a jack to bring the hub assembly back up and tighten down the nut holding the sway bar to the control arm and done ^_^ took longer to take the strut off then to put it back in did it this way in about 30 min including a beverage break
Oh And this make's my 15th Post YAY !!!
Heero88 is offline
Old 06-24-2011, 05:49 AM
Conecarver
BEJAY1's Avatar
Exactly!
BEJAY1 is offline
Old 06-24-2011, 10:37 AM
aackshun's Avatar
Pfffft, I strong-armed my control arm, too lazy to jack stand both sides of the car.
aackshun is offline
tarun900
19
12-20-2021 06:57 PM
maxima-junky
10-07-2015 06:13 PM
RealityCheck
10-02-2015 06:34 PM
JakeOfAllTrades
09-30-2015 03:16 PM
HerpDerp1919
09-29-2015 02:02 PM
Quick Reply: Stuck on strut knukle
