View Poll Results: short ram or cold air
short ram
19
54.29%
cold air (in the fender)
45.71%
Voters: 35. You may not vote on this poll
Old 06-21-2011, 10:42 AM
maxed_out_99's Avatar
sup org,
im just curious as to what has worked the best for low end torque for these engines i seem to get mixed results
i personally have a cold air
maxed_out_99 is offline
Old 06-21-2011, 10:49 AM
DIAMONDS98SE's Avatar
seriously?...how do you have as many posts as you do, and not realize there are hundreds of threads EXACTLY LIKE THIS ONE
DIAMONDS98SE is offline
Old 06-21-2011, 10:56 AM
yes seriously like i said above i found mixed results did you read? i want to know what will get me out of the hole the fastest
Old 06-21-2011, 10:59 AM
blindsteal's Avatar
i would say CAI
I just finished reading a thread about a guy who hooked up Torque (android app) to a bluetooth OBDII scanner
and he found that the intake temps were much cooler than with the short ram intake
imo makes sense since the short ram is gettin air from the engine bay area
but then again i'm no expert and i'm sure someone else can step in here after this comment...
blindsteal is offline
Old 06-21-2011, 01:30 PM
njmaxseltd's Avatar
Stock
[closed]thread[/closed]
njmaxseltd is offline
Old 06-21-2011, 01:57 PM
Snypa's Avatar
Originally Posted by njmaxseltd
Stock
your getting out the fastest right now.
Snypa is offline
Old 06-21-2011, 02:20 PM
99BlackMaxMS's Avatar
Neither. Go big or go home
99BlackMaxMS is offline
Old 06-21-2011, 06:29 PM
2000_MAXIMA_KING's Avatar
For low end short ram of course, especially for us autos all we care about is short and midrange so we can beat traffic! this aint nascar son
2000_MAXIMA_KING is offline
Old 06-21-2011, 08:44 PM
gregmaxin's Avatar
i dont think theres much of a difference in either. personally i think a stock setup is better than a short ram since with a short ram your just dragging in warm air from the engine bay. the only cold air intake that makes a difference is a prcai since its getting air from inside the fender and not the engine bay, and even that difference is not that much. just my .02
gregmaxin is offline
Old 06-21-2011, 08:54 PM
what does that mean im confused
Old 06-21-2011, 09:03 PM
He means SC/turbo, or nothin'.
The Wizard is offline
Old 06-21-2011, 09:19 PM
aackshun's Avatar
These guys here.....
aackshun is offline
Old 06-21-2011, 10:12 PM
i guess im going home
Old 06-21-2011, 10:32 PM
PRCAI or stock for us auto guys.
ChrisMan287 is offline
Old 06-22-2011, 06:10 AM
cashoit's Avatar
I jus came from a Formula D Drift competition . EVERYONE there had a short ram or CAI. No one is stock.
Its undeniable that with the cone filter u have more surface area for pullin in larger volumes of air. However, warm air robs the engine of power. The CAI SHOULD pull a little harder than the SRI. It jus depends on which u want to install.
I been saving up for the Secret Weapon Weapon R intake.
cashoit is offline
Old 06-28-2011, 07:21 PM
Nissanserguy's Avatar
I made a ram air setup on mine, Kept stock air box and ran a flex tube down to the bottom of car and used the OEM scoop. Also put a K&N drop in. Pulls nice, especially on the freeway or high speeds.
Nissanserguy is offline
Old 07-03-2011, 10:33 AM
sjtech's Avatar
Originally Posted by IAMxCHRISx
with the short ram u dont have to worry about soaking ur filter
agreed, it may be the fact that the area i live in is prone to minor flooding, but ive seen a few CAIs spell doom for an engine from sucking in water. my favorite thus far was a brand new cadilcac cts witch comes stock with the intake routed very low (so it would work as a CAI) it needed a long block, at $12,000 (he could not find used engine), before labour and taxes. because he drove it through deep water, it was not waranty.
sjtech is offline
Old 07-03-2011, 01:01 PM
Rods03Max619's Avatar
I like the CAI but going to make a SRI just to see how it acts...
Rods03Max619 is offline
Old 07-03-2011, 01:04 PM
MAXiPAD72O's Avatar
+1
MAXiPAD72O is offline
Old 07-03-2011, 01:05 PM
MAXiPAD72O's Avatar
Old 07-10-2011, 01:09 PM
UncleSmitty's Avatar
sup org,
From what I hear/read/know, an SRI does increase low-mid horsepower and the CAI is mid-high. If you're gonna do an SRI then may I suggest NWP spacers to drastically reduce the engine heat. IMO a CAI shouldn't go on a daily driver as it may not be as ideal for engine. Here in FL with all this stop and go traffic, a CAI is definitely not an ideal intake for me...
UncleSmitty is offline
Old 07-10-2011, 01:30 PM
IslandMax's Avatar
I have a PR cold air, drive my car daily. Ive switched it from short ram to cold air a couple of times. There really isnt noticable power loss or gain between the two. The sound is the only major difference. Also the heatsoak is not coming from the intake manifold itself (thats a whole different problem all together). The fact that the cone is right in the hot *** engine compartment and is sucking up all that hot air that the rad is blowing out is the downfall of it. Also the running through puddle and soaking the filter on a CAI is all on the driver. Gots to watch out for the puddles
IslandMax is offline
Old 07-10-2011, 02:29 PM
Everyone has their own opinion and everyone's personal pros and cons mixed with dyno numbers have thrown the OP off which is why they're here.. . what I've learned from my personal experience is just research and do a trial and error. Buy a new or used, preferably used, SRI on here or CL and try it out for yourself, then compare. People will always try to contradict numbers from a dyno and argue against EVERY element that went into the dyno like mods used at the time, computers, etc so it can be a headache. You already have a CAI, buy and try an SRI f*** it, if it doesn't work then sell it..
Old 07-10-2011, 02:46 PM
D I R T Y I 3 0's Avatar
CAI. Son.
D I R T Y I 3 0 is offline
Old 07-10-2011, 05:06 PM
Ryan95gle's Avatar
I'm running a Stillen SRI and its some good sh*t!
Ryan95gle is offline
Old 07-10-2011, 09:00 PM
funny you should say that... i convert my cai to a short ram for winter but its winter so the ambient temp is much colder which is why i was wondering what the best for low end torque is ive heard so many different things and would like to know what "most" people have experienced on their own. thus the reason for the pole. and the aem intake i believe is in front of the hot *** radiator so the difference in the fender is also a concern of mine
Old 07-11-2011, 06:49 AM
cashoit's Avatar
when i get that weapon R secret weapon i will do a comprehensive review.
cashoit is offline
Old 07-11-2011, 08:19 AM
sfhellwig's Avatar
Well when I came on this forum everything I read said that a CAI will gain on the low and lose on the top end. And that a short ram will have better top end but lose torque on the low end. That's why so many people will tell you that stock is best because it doesn't have a loss region, it's just more consistent across the board thus making it "best." Two issues: 1) That was a few years back and every response was for stock, so I guess people have changed their minds or the membership has just rotated out enough that everyone is back to their own opinion and the members who accepted the "stock only" approach are not so frequent. 2) I came from the B14/GA16 arena and if you didn't have dyno numbers to back it up, you may as well not even state it. Butt dyno counts for nothing, and I have never once seen a dyno chart posted for a Maxima comparing intakes (never searched, just never seen it cited as evidence). Now I was following the other platform more closely and from it's early development (was driving a 98 and reading in 2000). Since everyone that claimed "stock only" was citing loss of torque I would assume they were looking at an actual dyno readout. And I hope that someone pops up a scan of one so I can see it for myself. But to this day I still haven't seen a dyno comparison so no one can actually say which does what except for sound. Does any one at least have ETs of before and after an install? Until someone has actual quantitative data, this discussion will never have a CORRECT answer. Just opinions and educated guesses.
Flame if you want but go to any auto forum with intelligent people who want actual proof and the story will be the same.
To the OP, you want off the line faster. By logic a CAI usually accomplishes this. I personally have no need for top end gain as I don't race, so there's no reason for me to pursue top-end gain. I just left mine stock because this is the family car.
sfhellwig is offline
Old 07-11-2011, 08:47 AM
cashoit's Avatar
I agree that we need dynos to really quantify the discussion. Remove fact from fiction.
Any dyno i have seen of before and after with SRI or CAI versus stock has historically shown improvement over stock or higher HP numbers.
Like i stated above..i went to a car show/drifting competition and EVERYONE was running either a SRI or CAI. NO ONE was runnin a stock intake. Watch any car show and they always remove the stock box in favor of either a CAI or a SRI. These guys make their living with speed...i tend to agree with them on matters of going fast
cashoit is offline
Old 07-11-2011, 11:01 AM
Thank you everyone for contributing to my thread there is some very usefull info here.
And pertaining to the dyno comment, at school I dynoed my car with a drop in K&N and the factory box I then dynoed it again with a eBay short ram these were the results; hp-1 gained
Tq-2 gained
I never tested the cold air
Old 07-11-2011, 12:46 PM
sfhellwig's Avatar
Since you dynoed it both ways, please scan and post your slips. Most people will read a gain of 1hp and 2 ft/lbs as a complete waste of money. What counts is the torque curve underneath the peak. Many of the old intake dynos I would look at would show huge gains in the lower RPM band. If you gained 7hp @ 2500 rpms then that means a lot more than 1hp @ peak. It would also show you if it levels off till redline or falls flat on it's face. Sometimes people push a certain tune and start to lose the top above peak. That's when you back it off and take a better overall curve instead of a better single peak number. But congrats on dynoing. Now share so the rest of us can see what you feel.
Old 07-11-2011, 02:36 PM
I'll look for the slip when I get home but it's kinda embarrassing
Old 07-11-2011, 05:01 PM
maxispeed's Avatar
why not mix the two?
maxispeed is offline
Old 07-11-2011, 05:49 PM
VisciousMo's Avatar
Is there really a night and day difference between both?
VisciousMo is offline
Old 07-12-2011, 12:00 AM
CAI - low to mid.
SRI - mid to high.
Old 07-12-2011, 12:28 AM
SandyMax96's Avatar
Not trying to rectify or contradict anybody. If anything's it's given me an incentive to go out and test the stock vs. the SRI. I personally have the SRI and have seen a slight change in low end, pulls harder, I can definitely vouch for that. However, when I switched over to synthetic I felt a bit more of a drag mostly from all the F***ING heat the oil produces in the bay! So, while working on repainting my car, I decided to cut a hole in the wheel wall so that it could access some more "direct" colder air from the outside. I did notice that it does pull in more air into the bay and that's a great sign! Albeit, it's not yet finished as I wish to fabricate a cone type of snorkel that would lead from the wall, to the fender oval shaped duct, and around a heat shield that protects my filter, to close it off and make it exclusive to the filter and only the filter alone. And being that I'm in cali, it's really rare when there's rain, especially in the IE. But from what I've heard, CAI = High End; SRI -Low End. and that's my multiple .02
SandyMax96 is offline
Old 07-12-2011, 12:43 AM
ef9
ef9's Avatar
Buy the CAI and install the AEM bypass valve, which prevents the intake from sucking in water if you hit a puddle. That's what I did with my PR CAI setup. I live in Hilo, the wettest city in the US.
ef9 is offline
Old 07-21-2011, 10:54 AM
ok, heres my dyno runs as i said its embarrassing run 2 is the drop in run 1 is the short ram
i also owuld like to mention at the time of the run my rear header was completely loose due to a "friends" help
the numbers are hard to see
RunFile_002.drf Max Power=162.25 Max Torque=166.70 drop in
RunFile_001.drf Max Power=165.62 Max Torque=168.08 short ram
Old 07-21-2011, 01:06 PM
aackshun's Avatar
^ You are the man!!!!
aackshun is offline
Old 07-21-2011, 03:17 PM
I wish I could have tested the cold air
Quick Reply: short ram or cold air
