fuel gauge sending unit
Old 06-06-2011, 07:03 AM
maxed_out_99's Avatar
sup org,
ok so my low fuel light no longer works. sooo... when i replaced my gauge lights with leds i decided to pull the bulb and check continuity and the bulb apears to be working properly. i have come to the conclusion that it is the fuel gauge sending unit. my question to you fine folks is...
220,000 miles.
1) im having trouble locating this part and it is not included with the pump but my pump is fine. where can i find one?
2) if i pull the pump at my mileage will it take a poo-poo?
any help would be appreciated
THANKS ORG!
maxed_out_99 is offline
Old 06-06-2011, 10:09 AM
DennisMik's Avatar
the part name & number is: Sender Unit-Fuel Gauge # 25060-4L700.
(reference: item # 8 @ http://nissan4u.com/parts/maxima/us_...llustration_1/ )
$134.55 at Courtesy Nissan
$120.91 at http://www.nissanpartszone.com/
I would suggest that you replace the rubber o-ring seal for the fuel pump whether you replace the sender unit or not.
The sender unit has a variable resistor that runs the needle on the gauge and a switch to turn the low fuel light on.
DennisMik is offline
Old 06-06-2011, 11:05 AM
cashoit's Avatar
my low fuel light doesnt work either.
Jus never let teh gas level get that low. Bang problem fixed
cashoit is offline
Old 06-06-2011, 12:01 PM
thats way i do it too but my mileage calculations are not accurate
MAN thats alot just for a little orange light im glad i dont have to pay labor
do you think the pump will dump if i remove it?
Old 06-06-2011, 12:02 PM
njmaxseltd's Avatar
They call them IDIOT lights for a good reason...
njmaxseltd is offline
Old 06-06-2011, 12:15 PM
max ride 41's Avatar
why would the pump go bad??? just removing and putting it back should'nt change anything. i have the same mileage on my 95 and the same problem, if the fuel pumps working, who cares about the light. save your money man....
max ride 41 is offline
Old 06-06-2011, 12:33 PM
DennisMik's Avatar
The pump shouldn't fail just because you remove it. Handle it gently, don't drop it or throw it.
BTW, don't forget to release the fuel pressure before you disconnect the hoses.
Old 06-06-2011, 02:13 PM
If your SES light is missing would you know if your secondary o2 is failing? Causing you to fail emissions.
Old 06-06-2011, 02:16 PM
I've seen all kinds of crazy things happen just by removing one simple part and it's old that like taking an 85 year old lady for a hike
Old 06-06-2011, 03:06 PM
what??? thats crap, i've removed oem $hit that was 14 years old and put it back on and no issues. sensors, ac compressor, entire dash like 6 times. if you know what your doing, it should'nt be a problem. thats what the fsm is for. stuff will break, but something like that??? i doubt it.
Old 06-06-2011, 04:20 PM
m3killer's Avatar
It's cheaper to just refill the tank every few days
m3killer is offline
Old 06-07-2011, 07:39 AM
cashoit's Avatar
yea maxed man, removing the pump shd cause it break. If u got the cash and the mindset to change the light then change it man...its your car.
cashoit is offline
aw11power
10-10-2021 04:57 AM
Miket2006
03-01-2021 03:55 AM
jaydot901
09-29-2015 01:18 PM
Max Nu-BE
09-28-2015 10:25 AM
Quick Reply: fuel gauge sending unit
