engine idling at 3k+ rpms
Old 05-25-2011, 08:19 PM
GGENIUS's Avatar
today i cleaned my MAF, IACV, EGR, throttle body, U + L IM and installed NWP spacers. finally get done everything and start the car and its idling at like 1500. then it starts creepin up and eventually starts idling at 3000-3300. now it pretty much stays at 3000. what could this be? we triple checked everything and every hose and harness is hooked up
GGENIUS is offline
Old 05-25-2011, 08:28 PM
MaxJammin's Avatar
maybe a vacuum leak on the u/l intake? just my 0.02
MaxJammin is offline
Old 05-25-2011, 09:31 PM
styliztik's Avatar
did you adjust the idle with the screw when you put everything back together? you're supposed to
styliztik is offline
Old 05-25-2011, 09:36 PM
MaxJammin's Avatar
forgot all about this!
Old 05-25-2011, 09:38 PM
FallenOne's Avatar
Fail, No don't touch that ****.
Vaccum Leak or your tps.
FallenOne is offline
Old 05-25-2011, 09:59 PM
MaxJammin's Avatar
when i did mine i only had to adjust it because it was broken off and i had to drill it out and re-tap it, maybe thats why i thought it was right, because mine has no initial setting to start with, but, TPS or vacuum leak are my thoughts too
Old 05-26-2011, 03:23 AM
GGENIUS's Avatar
yeah we tried messin with the screw already it wasnt the problem. im assuming it has to be a vaccum leak too i just dont get from where. would the TPS throw a code? im get that **** scanned again today.
GGENIUS is offline
Old 05-26-2011, 09:19 AM
99zx2's Avatar
make sure your iac is not stuck open.
99zx2 is offline
Old 05-26-2011, 09:30 AM
aackshun's Avatar
There's your vacuum leak.
Spray WD-40 around that area, listen to see if your idle changes.
aackshun is offline
Old 05-26-2011, 02:28 PM
GGENIUS's Avatar
we figured this out after work when we had some light. by the time we started the car last night it was 9pm and dark. we didnt adjust the throttle cables to be longer than before to make up for the spacer. dumby mistake.
GGENIUS is offline
Old 05-26-2011, 08:24 PM
aackshun's Avatar
Darn, I was close, I was in the right ball park lol.
aackshun is offline
Old 05-26-2011, 09:13 PM
FallenOne's Avatar
LAWLZ!~
Old 05-27-2011, 03:41 AM
GGENIUS's Avatar
lol indeed! lesson for future NWP installers.
GGENIUS is offline
Old 05-27-2011, 12:27 PM
GGENIUS's Avatar
ive got another question is our EGR tube vacuumed? or not? because i hear a slight hissing sound from around that area and i couldnt get that one nut on the bottom of the EGR tube all the way tight.
GGENIUS is offline
Old 05-27-2011, 12:31 PM
cashoit's Avatar
YEs it is. But i dont think it will cause much of issue cuz the whole point of EGR system is to keep the cylinders nice and hot. If atmospheric air mixes with exhaust gas the worst that shd happen is that the exhaust temp decreases a bit.
cashoit is offline
Old 05-27-2011, 12:34 PM
GGENIUS's Avatar
but it wont throw a code? half the point of all i did was to pass inspection. but it seems like she sounds a bit rough at the exhaust end of the car. like random coughs. and then the slight hissin under the hood.
GGENIUS is offline
Old 05-27-2011, 12:54 PM
Jliner's Avatar
bingo if the vacum line/hose to the EGR is broken or leaking it would cause it to idle high you can test if the EGR is working by removing the hose (ussally on the under side of the ERG) and apply a negitave vacum to it ... if it works the car should idle down.... if this happens and you replace that hose (assuming it has a crack/leak) that should help your high idle although that seems slightly high for just a vacum line leak justr one thing to eliminate from check list i guess good luck bud !
Jliner is offline
Old 05-27-2011, 12:57 PM
GGENIUS's Avatar
thanks for the reply i solved the high idle problem. it was the throttle cable length due to the spacers i installed. im just tryin to see if not tightening that last egr nut will do anything negative.
GGENIUS is offline
Old 05-27-2011, 01:40 PM
defiance's Avatar
Both guide tube bolts must be on nice and tight and the gasket be in decent condition.
Its a real pain in the a$$ but its gotta be done, I learned that lesson the hard way.
defiance is offline
Old 05-27-2011, 01:49 PM
GGENIUS's Avatar
good lookin out. i see multiple people sayin theyve gone years now without the gasket in the egr tube though.
GGENIUS is offline
Old 05-27-2011, 02:07 PM
defiance's Avatar
In my case I had both bolts only hand tightened and no gasket as it was laying somewhere in the engine bay. Car woudnt run for shlt so the next day I found the gasket and reinstalled with real tightness, car was fine after that
defiance is offline
Old 05-27-2011, 02:31 PM
GGENIUS's Avatar
word my bolts up top were on tight, its one of the nuts on the lower part of the EGR tube that i cant get all the way tight. its the one you can see, thats behind a another tube. making it impossible to get the nut and washers off.
GGENIUS is offline
shilov
02-19-2024 09:40 PM
captchaos
03-15-2016 12:18 PM
bryants95max
10-02-2015 12:52 PM
ballerchris510
09-10-2015 09:35 PM
slowlifer
09-08-2015 05:53 AM
Quick Reply: engine idling at 3k+ rpms
