chugging, bucking and stalling problem?
Old 05-25-2011, 12:55 PM
sho89mtx's Avatar
I have a 1997 Nissan Maxima SE and a while ago a check engine light came on and had it read by a mechanic and they said it was the knock sensor. A couple of weeks ago it was stalling on me, chugging really bad, so I figured it must be time to get the knock sensor fixed. Took it to the mechanic, he took out my knock sensor, said it was cracked in half, installed a new one and sent me on my way. I currently don't have any check engine lights on, but it still chugs, bucks at 40+mph and stalls almost everyday at stops. What could be the problem? Anyone have any maxima related issues that this sound familar with? My dad thought it might just be bad gas since I fill up with 7-11 cheap gas and put some of that chemtool injector cleaner, but 2 days later, it still runs like crap. Please help,
Scott
sho89mtx is offline
Old 05-25-2011, 01:21 PM
Kevlo for President
Kevlo911's Avatar
Sounds like a bad MAF
Kevlo911 is offline
Old 05-25-2011, 01:33 PM
mikechambers's Avatar
took the words right from my mind. my previous max was a 97 (RIP) and i had a hell of a time workin out the stalling and hesitation. the maf goes out on the 97s because of a bad seal at the front of the assembly (closest to the air box) best thing to do if your not lookin for show quality is to use duct tape and common sense to seal it up.
mikechambers is offline
Old 05-25-2011, 02:02 PM
sho89mtx's Avatar
thanks guys, how much is a MAF for my car to get fixed at a shop?
sho89mtx is offline
Old 05-25-2011, 02:08 PM
Kevlo for President
Kevlo911's Avatar
I would just buy a working maf from this site in the classifieds and change it yourself. It is one connector, 4 bolts, and 1 hose clamp. For a novice, it should take 30min max.
Kevlo911 is offline
Old 05-25-2011, 09:06 PM
matt82228's Avatar
I'd find someone local to swap out their intake with you. I remember if the MAF is bad, you will definitely get an CEL. Do you have an aftermarket intake? Are all the vacuum lines hooked up?
matt82228 is offline
Old 05-25-2011, 09:25 PM
chongher's Avatar
Either that or might be bad coils or a bad coil. I got a bad coil before without a check engine light. And my car was running very poor with the choking and lost off power.
chongher is offline
Old 05-26-2011, 06:49 AM
njmaxseltd's Avatar
Your initial check engine light was not set because of the knock sensor, there had to be another code along with the KS code to make the light come on.
Your mechanic should have seen the other code before he cleared it.
Before you start swapping parts out, check for any stored or pending error codes.
It must have detected the problem before, and it most likely will again. Don't be surprised if it throws another knock sensor code, just ignore it. Might take a few days, hopefully sooner.
njmaxseltd is offline
Old 05-26-2011, 08:10 AM
cashoit's Avatar
yup, Knock sensor dont cause CEL.
Clean TB and MAF per how tos. Check for codes.
EDIT:
Throw some chevron techron in the fuel tank
cashoit is offline
Old 05-26-2011, 09:52 AM
sho89mtx's Avatar
k, I have the codes on a piece of paper from my mechanic, when I get home, i'll look at it and post them. I really appreciate all of your help guys. I think I can handle the MAF installation myself, just wondered how much the part costs and the mechanics always tell me that Nissan's like OEM parts and sometimes don't work well with aftermarket ones, is that true or a myth?
sho89mtx is offline
Old 05-26-2011, 01:33 PM
njmaxseltd's Avatar
With engine management parts, it's usually better to stick with OEM.
Instead of purchasing a new OE part, consider a used one.
Check the For Sale section of these forums to help you locate the part you may need.
Old 05-27-2011, 06:47 AM
sho89mtx's Avatar
ok, talked to the mechanic, it originally shot out a p0325, which they said was a knock sensor code and now it's replaced. then they say it had the evaporation commisin codes P0450, p0445 and p0443
does that help narrow it down to anyone?
also they said the MAF is $572, that seems crazy!
sho89mtx is offline
Old 05-27-2011, 07:00 AM
cashoit's Avatar
u got EVAP issues. Its prolly EGR solenoid valve. Use the FSM to diagnose
cashoit is offline
Old 05-27-2011, 08:06 AM
sho89mtx's Avatar
I hope I don't sound too ignorant, but what's the FSM? Also how much is an egr solenoid valve and is it something I can do on my own like the MAF or would I have to get a mechanic to install it?
sho89mtx is offline
Old 05-27-2011, 02:20 PM
sho89mtx's Avatar
does anyone else thing this is the problem judging by those codes?
sho89mtx is offline
Old 05-28-2011, 12:24 PM
sho89mtx's Avatar
I looked at the FSM, it said one of those codes was a fauly Evap Solenoid control valve, so I went out, spent $106 and replaced it with a friend and it still drives like crap, and even through a check engine light on.
I've also noticed before it stalls it makes a weird sound coming from the back, could this a fuel pump or something?
sho89mtx is offline
Old 05-28-2011, 03:41 PM
Trini Boom's Avatar
Ok you need to slow down a bit herwe and properly diagnose your car. First off, those codes have nothing to do with the way your car is operating. They are just emissions to pass inspections.
You say that your car is bucking. Does this occur only in D?? If so, is the car fully warm or still cold and warming up?
Next, when was the last time any maintenance work was done on the car before this mechanic? There is a lot of unknowns here which you need to fill us in on. Out of curiosity, what color is your tranny fluid?? Its not related to your problem but it will help to know the condition of the car.
Trini Boom is offline
Old 05-28-2011, 04:49 PM
sho89mtx's Avatar
My car does it any gear I put it in once it does it. D, Reverse, Park. Usually is real bad when i'm at a stop, it drops the rpms', makes weird noise from the back of my car and then turns off. So I have to put my car in Park at stops and keep the rpm's up to about 1500 or 2000 rpms for it not to stall. It happens fully warm, cold, all times.
Had the car worked on a lot, also had the fluids checks, they all were fine. My car has 177k on it, but used to drive like a new car. It's all of a sudden it's driving like crap! Replaced a knock sensor for $450, then they said the codes didn't go off, but they found a seal around my gas tank that was bad, so they replaced that and it took the codes off, then it started doing this, I went out and replaced the EVAP control valve since it was located exactly where I was hearing the noise, it made sense to me and because it was a common problem on our cars, now i fixed it and runs even worse. I don't know what to do, but maybe sell the car right now. Put close to $600 on a car in the last 2 weeks.
sho89mtx is offline
Old 05-28-2011, 06:11 PM
Trini Boom's Avatar
Don't give up yet my friend. The car only gets this bad from neglect. If I understand you correctly, if you come to a stop with it in D, it will cut off correct? What I would suggest is starting with the basic stuff. Remove your spark plugs and see the condition of them if they have any traces of oil or discoloring at the tip. Second, I would remove the IACV (Idle Air Control Valve) and give it a good cleaning with Throttle Body Cleaner. Post a pic of it before cleaning so I can see how much carbon is built up. Could be your EGR tube is clogged also which could also be the PCV valve is clogged which could also cause this problem. This is why I asked the condition of the car.
Old 05-28-2011, 07:23 PM
sho89mtx's Avatar
k, definately gonna try that stuff this weekend. THanks for the help,
Scott
sho89mtx is offline
Old 05-30-2011, 09:02 AM
sho89mtx's Avatar
tried all that stuff, found the seal around the MAF cracked, but not really bad, used duct tape to seal it, still nothing worked. I have no clue what it is right now, but nothing has fixed it
sho89mtx is offline
Old 05-30-2011, 09:30 PM
Trini Boom's Avatar
What about all the other stuff that I asked about??
Old 06-01-2011, 08:14 AM
sho89mtx's Avatar
we did all My dad could help me with. We couldn't understand from the diagrams where the IACV was, so that's the only part we didn't do. We took apart the airbox,unclamped it, cleaned my K&N air filter, ran some throttle body cleaner in the throttle body etc, but still not luck. The only thing my Dad did fix was the stalling problem. He did something to my Idle to increase it in Drive from 500rpm to 800rpms and now it doesn't stall anymore. It still drives like poop, but doesn't die anymore. My friend is gonna let me borrow his Code reader and hopefully i'll get to do it again because since I installed the EVap Solenoid contorl valve, the check engine light popped back on and it might be different codes
sho89mtx is offline
Old 06-01-2011, 10:26 AM
cashoit's Avatar
sounds like a bad maf to me. Have u tried cleaning it
cashoit is offline
Old 06-01-2011, 12:59 PM
sho89mtx's Avatar
yes we took it off, cleaned it, saw that the rubber seals was a little cracked and weather, but not much, so we sealed it with duct tape like they suggested, but still didn't help
sho89mtx is offline
Old 06-01-2011, 01:13 PM
luke95gxe's Avatar
iacv is the thing off the back of the throttle body with diff colored wiring plugs on it
luke95gxe is offline
Old 06-01-2011, 01:43 PM
66slim's Avatar
I am having similar issues with stalling. throws knock sensor code and rear o2 code. just had plugs replaced and cleaned intake area up when changing valve cover gaskets. 95 max se with 180000 miles. any ideas? i am going to try iacv next
66slim is offline
Old 06-01-2011, 02:29 PM
sho89mtx's Avatar
ok, just did the code reader and it pulled up thse 3 codes:
1st code: P0446
2nd code: P0100
3rd code: P0446
now time to do my research on see what the problem is
sho89mtx is offline
Old 06-01-2011, 02:44 PM
bobflood's Avatar
1st code: P0446
2nd code: P0100
3rd code: P0446
P0100 is for the MAF. P0446 is an EVAP system code. For P01000 just changed my MAF; got a reman Nissan one on line from autopartsexpress.com for about $157 after core return. Cured the drivability problem instantly. P0446 was caused by a broken vacuum cut valve bypass valve; it was on a bracket just outside the EVAP cannister just behind drivers real wheel. All those parts from a pull-a-part lot. EVAP issue did not affect drivability; just needed to get the CEL off for inspection.
bobflood is offline
Old 06-01-2011, 02:58 PM
sho89mtx's Avatar
So I need a new MAF then? Not sure about the other thing your talking about. But u said it doesn't affect how it drives and this one is definately a driveablility issue
sho89mtx is offline
Old 06-01-2011, 06:01 PM
luke95gxe's Avatar
if you are having a maf code then it prolly your maf u can find them here in the 4th gen classsified for about 40 shipped to your door i have 3 working tested maf and i know fallenone also have mafs for sale
Old 06-01-2011, 06:07 PM
sho89mtx's Avatar
ok, but the MAF's have MAF sensors already in them? I'm literally ignorant about autoparts, so don't be afraid to be honest and call me an idiot. I fully admit i'm an idiot about car stuff, that's why i'm constantly getting hosed by mechanics, I think they can sense it on me
sho89mtx is offline
Old 06-01-2011, 06:10 PM
GGENIUS's Avatar
what did you clean your maf with?
GGENIUS is offline
Old 06-01-2011, 06:12 PM
sho89mtx's Avatar
chemtool fuel injector/carborator cleaner stuff
sho89mtx is offline
Old 06-01-2011, 06:13 PM
GGENIUS's Avatar
that probably ruined it if it wasnt already ruined. you gotta use the maf specific cleaner.
GGENIUS is offline
Old 06-01-2011, 06:18 PM
sho89mtx's Avatar
well it didn't change a thing, didn't get worse or better, just stayed the same, so it must of been toast already.
sho89mtx is offline
Old 06-02-2011, 07:06 AM
luke95gxe's Avatar
yeah man they come with the sensor in them bro its a sealed deal
Old 06-02-2011, 07:25 AM
cashoit's Avatar
Yo man this thread lol...
Sho89, jus cop the MAF off Luke and u good. If u getting a code for the MAF then yur MAF is toast.
cashoit is offline
Old 06-02-2011, 08:10 AM
sho89mtx's Avatar
k, if u can guarantee they are working, i'm in! PM me with your details and price. I have a paypal account, so if u have one, that would be the easiest.
sho89mtx is offline
Old 06-02-2011, 08:22 AM
luke95gxe's Avatar
you got pmz
Quick Reply: chugging, bucking and stalling problem?
