help me please i am locked out
my car has been having battery problems recently so i decided to replace the battery i go out to get in push unlock and nothing well ok i will just unlock it with the key nope trunk maybe wrong again apparently the key i got starts it and thats it how can i get in without calling a locksmith
He has a 99 that uses the chipped key. Only a chipped key will start the car, the valet key will not because it has no chip. But the chipped key will open the doors.
I have no idea what this problem is. If he has road service with his insurance, call them or a locksmith.
go to your local nissan dealership. Hopefully you have either your registration or title with your name on it. Get them to make you a key. They'll be able to look up your vin and make you a key that way. If you have a 99, just ask for a key to be made without the chip since it wouldn't work anyways. btw, better make a spare for the one in the ignition cause you might be screwed if you lost that only one you have
I have this same issue, the problem is that my key is warn out. The key will still start the car but i had to play around with it alot for the doors. Now that i know it will lock the passenger door and unlock the driver side. Your best bet is to spend the money to get a new key made or figure out how to wiggle that key around to unlock
Try the passenger door? can you get in through the trunk of a 4 gen? (fold down seats?)
wiggle the key as has been mentioned. the only one that worked perfectly on my 3 gen was the factory key. I lost it a few years ago and went to my copy, and it sucks. have to wiggle the key every time and eventually it'll work.
all else fails, you can pop the hood and replace the battery without getting into the car, but it's a pain.
i would love to pop the hood then just charge the battery and get in i didnt wanna get raped for 40 bucks then another 50 or so to make the key at the dealer but i guess its my only option and yes i have just been using the fob till now would the non chipped key work to get in to the doors thought that they communicated with the nats guess not
hey im so sorry to bring up my topic in your thread but guys i need help and i cant start a thread without 15 post. so here it goes i got a 96 maxi that ran great untill just recently someone broke in and tried to steal it. they broke the ignition off and now the car does not start and the lights keep blinking. i think its in theft mode but when i go to the driver door it wont shut off the alarm anymore. the guy took fuses out and did a couple things. i need my car back can anyone help me
back to the original subject, try jacking up the front of the car, removing the splash guards, and trying to pop the hood release from the inside of the hood. then you might be able to charge the battery.
called a local locksmith cut a key by code for 20 bucks lesson learned and prevented from happening again also getting new car battery only two years old thanks for all input and suggestions mods plz lock it up
James92SE
142
01-02-2024 09:23 AM
HerpDerp1919
09-29-2015 02:02 PM
Andy29
09-29-2015 05:32 AM
