J30 Retrofit in Progress
Old 04-17-2011, 06:50 PM
95Maxed's Avatar
Finished Product!!! Scroll to POST #3 to see progress pictures.
Off:
Angel Eyes:
On:
Output:
The Two Nissan Bred Beasts....
95Maxed is offline
Old 04-17-2011, 06:56 PM
luke95gxe's Avatar
lookin good man deff wanna see the out come
luke95gxe is offline
Old 04-17-2011, 07:02 PM
95Maxed's Avatar
Hey guys, i finally pulled the trigger. Im doing a j30 retrofit. I had/have no idea where to start, ChrisMan has been guiding me the whole way and I owe him.
J30's
Low Beam Projectors after I separated them
Housing
Test Fit
EDIT: New Progress
Painted Housings and Projector Shields
EDIT: Projectors Put Back Together and Painted
EDIT: Test Fitting, Everything is Painted
NEW PICS: RETROFIT FITTING SESSION!!!
UPDATED MAY 1st!!!!!!
Test output
UPDATED: Test Fitted them in the car!
BEAUTIFUL CUTOFF!
Close Up
95Maxed is offline
Old 04-17-2011, 08:51 PM
VQ'rInWLA's Avatar
In for progress!
VQ'rInWLA is offline
Old 04-17-2011, 09:22 PM
95Maxed's Avatar
Originally Posted by VQ'rInWLA
In for progress!
Ill have pictures showing the whole process lol
95Maxed is offline
Old 04-17-2011, 09:24 PM
VQ'rInWLA's Avatar
Good stuff. Im about to attempt a retro also so the pics would definitely help!
Old 04-17-2011, 09:31 PM
95Maxed's Avatar
Its really not as hard as I had imagined. Im decent with wiring and electronics so that should be easy enough. I was just concerned about the baking open lights, and cutting them and all that junk. Its a learning experience lol, and a fun one at that.
95Maxed is offline
Old 04-17-2011, 09:32 PM
VQ'rInWLA's Avatar
My thoughts exactly. Thats what was holding me back....Im gonna attempt mine with a heat gun though. Hear that works also.
Old 04-17-2011, 09:39 PM
Silfrgluggr's Avatar
Thanks for putting the ruler there :P and yea baking is always suspenseful the first time, me and my buddy put his accord headlights in the oven a while back, now im all for it
Silfrgluggr is offline
95Maxed's Avatar
Dont even try. I attempted that to get the j30 headlights open and ended up cracking the glass on the housings into 3 pieces, only to end up putting it in the oven...
ChrisMan told me in the oven at 225 for 10 minutes, id say 10-12. That got the glue nice and soft for me and you just pry them apart with a screw driver.
95Maxed is offline
Old 04-17-2011, 10:32 PM
You know I've got you covered Andrew! Everything's looking good. J30 retro's FTW.
ChrisMan287 is offline
Old 04-17-2011, 10:37 PM
VQ'rInWLA's Avatar
**** it.....oven it is.
Old 04-17-2011, 10:39 PM
VQ'rInWLA's Avatar
Is that 10-12 mins on a preheated oven?
Old 04-17-2011, 10:48 PM
I like to preheat. Throw them in for 5mins and start to work around the headlight but don't force it. If they're not ready, throw them in for another 5-7mins and by then they should definitely be good to go.
Old 04-17-2011, 10:49 PM
VQ'rInWLA's Avatar
Whatd you place em in the oven on? A plank of wood or something?
Old 04-17-2011, 10:51 PM
MaximaSpd85's Avatar
i use a baking pan, fold a towel and put the towel in the baking pan. and the headlight on the towel. i just feel that if i put the headlight right into the baking pan the pan would maybe melt the headlight plastic? idk....
IN for pics of painted projector insides!!
MaximaSpd85 is offline
Old 04-17-2011, 10:53 PM
btw, how do you plan to mount the projectors?
Old 04-17-2011, 10:55 PM
VQ'rInWLA's Avatar
Exactly which is why I was asking.
Old 04-17-2011, 10:57 PM
I use a plank of wood lol But the painted cutoff shield is gonna be cool they'll look like my high beams which have Lexus capsules.
But he'll be using epoxy to mount the projectors.
Old 04-17-2011, 11:00 PM
VQ'rInWLA's Avatar
Cool. Ill be JB Welding it. Also what best to use to reseal it back together?
Old 04-17-2011, 11:04 PM
i always just use the existing glue. put it back in the oven again to remelt the glue, and when u take it back out press it back together and the glue will dry again and seal it back together.
make sure yall aim them PERFECTLY the first time, since it will also be your last time if youre using epoxy and jb weld! good luck with that.
Old 04-17-2011, 11:05 PM
VQ'rInWLA's Avatar
Good enlightening tips yall much appreciated!!
Old 04-18-2011, 04:05 AM
95Maxed's Avatar
Yea, what Chris said, ill be using QuikSteel to mount the projectors and cover the big gaps in the rear of the housings. I sketched some lines even with the rad support bar as guides so they should be nice and even.
95Maxed is offline
Old 04-18-2011, 06:20 AM
Kevlo for President
Kevlo911's Avatar
Looks like you are set on using these projectors. But did you think about switching to a HID projector? I can't imagine doing all this work and not having a real HID projector in there. The halogen projectors will not be as bright and will not distribute light as well.
And if you are set on this projector, have you looked into a clear lens mod and spacing mods? Check out www.hidplanet.com; their forums cover all this and their forsale forum has tons of projectors.
Kevlo911 is offline
Old 04-18-2011, 06:33 AM
cashoit's Avatar
Yo maxed man,
u have taken that max from ashy to classy lol. Nice work man. Im in for the pics too
My only concern with HIDs is that with my amp/sub installed, i may start to kill my alternator. Any retrofit guys have problems with this? how many watt rms sized system?
cashoit is offline
Old 04-18-2011, 06:35 AM
Kevlo for President
Kevlo911's Avatar
Originally Posted by cashoit
Yo maxed man,
Hid's only use alot of power on the initial startup, after that they only use 35w which is less than a standard halogen bulb. Make sure you don't use the stock wiring and you will be fine. I have HID Heads and Fogs, electric oil pump, 800w, system and a bunch of other stuff on the stock alternator; it works fine.
Kevlo911 is offline
Old 04-18-2011, 07:10 AM
95Maxed's Avatar
Kevlo: yea, i'm set on using these projectors, theyre all I can afford right now. Eventually, yes I will switch to the clear lenses. I aslo know there will be a slight hotspot when using these, but based on the output pics from ChrisMan, its not too bad.
Cashiot: All my HID kits have always been plug and play and I've never had problems with them. Thanks for the compliment on my car! I've poured money, blood, sweat and tears into it lol.
95Maxed is offline
Old 04-18-2011, 12:07 PM
Redline Maxima's Avatar
looks good man, looking forward to the progress pics...
Redline Maxima is offline
Old 04-18-2011, 12:29 PM
95Maxed's Avatar
Thanks Lav, I'm gonna buy the paint for the insides of the projectors and the housings today. Gonna paint the inside of the projectors yellow, sorta like non illuminated demon eyes, and then the housings black.
95Maxed is offline
Old 04-18-2011, 05:36 PM
Quiksteel can easily be cut or chiseled off so if you do have to reaim it's not a problem. But remember you should be able to use your stock adjustment screws if you have to.
As for sealing them up I always apply a fresh batch of butyl tape, heat up that tape a little and slap the lens on, press them together as much as I can, then throw them in the oven and heat/press a few times. Once they're pressed I use clamps to keep them together as the butyl hardens.
Old 04-18-2011, 05:39 PM
321VQ35MAX's Avatar
We gonna have some bbq'd projector's??
321VQ35MAX is offline
Old 04-18-2011, 06:19 PM
95Maxed's Avatar
New Pics up top!
95Maxed is offline
Old 04-18-2011, 06:26 PM
VQ'rInWLA's Avatar
Even more intrigued now. What kind of paint did you use in the pj's?
Old 04-18-2011, 06:33 PM
95Maxed's Avatar
Engine Enamel
95Maxed is offline
Old 04-18-2011, 06:35 PM
VQ'rInWLA's Avatar
Definitely wanna see how that comes out. But is output affected? Will it show a hint of yellow?
Old 04-18-2011, 06:37 PM
95Maxed's Avatar
Output should not be affected, the cutoff should actually be a bit sharper b/c of the paint. There will be no yellow tint when the lights are turned on.
95Maxed is offline
Old 04-18-2011, 06:42 PM
VQ'rInWLA's Avatar
I see. Keep up the progress and pics bruh!
Old 04-18-2011, 06:44 PM
95Maxed's Avatar
New Pic, lol. Up top.
95Maxed is offline
Old 04-18-2011, 06:47 PM
VQ'rInWLA's Avatar
Doesnt look too bad. I may be swayed upon pics of the improvement of the output.
Old 04-18-2011, 07:05 PM
95Maxed's Avatar
Ive heard it works with some projectors and others it doesnt. Its really just for show. Keep in mind that these are halogen projectors. In order for me to have a really nice clean cutoff i will need to order some 3 inch Clear Lens' and spacers for them. But that will come in the future, down the road.
95Maxed is offline
Quick Reply: J30 Retrofit in Progress
